ocei77
7
Everything posted by ocei77
Large screwdriver from behind. Can even tap with a piece of wood against the sprocket, rotating to even the movement. O.
The chips on the pulleys are benign, If they are not cracked I wouldn't replace. If you want to, a junk yard would be your best option. I've never had to use a puller to get them off. You are replacing the idlers, right? Remove oil pump and tighten screws on back if loose. Don't tighten the valve covers until after you have tightened your sprockets. A 1" open end will fit the flats on the cams to hold them. Careful of torque on cam bolts, the specs are very light. I know where the plug goes, but not enough knowledge to tell you where it goes w/o looking at an engine. Am sure someone will chime in here. Continue to take your time and all will be well. O.
EJ25 Rebuild
ocei77 replied to jread's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The turbo gasket ending in 642 will work on the ej25D. O. -
EJ25 Rebuild
The Stant Xactstat #48457 is exactly the same as Subaru's unit. O. -
Check your vacuum lines, especially the small one to the fuel presure regulator. If the 08 has the hose from the IAC to intake check that too. O.
- 7 replies
- usedtiming
- wont start
(and 1 more)
Tagged with:
