ocei77
7
Everything posted by ocei77
Make sure you have not dislodged the vacuum line that goes to the pressure solenoid on the IM. The other side goes to the fuel pressure regulator. If you don't have vacuum, you won't get fuel. O.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
Relays seldom go bad. I'd make sure the ignition fuse is good. Pull the outlet line from the fuel filter. Turn the key to on, that will short cycle the pump. If you get fuel, that's not your problem. If you don't I'd check the fuel pump, Just remove the cover and the connector. You should get 12v when the key is turned on. If you do, and the pump is not sending fuel. You have your issue. Download the fsm and go down the list. http://www.main.experiencetherave.com/subaru_manual_scans/ O.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
I saw that ad, but my daughter wants all seasons. Good find tho. 2 years ago I bought 4 Continental Contacts in 17" with 7/8 tread for $175, but had to drive 2 1/2 hours each way (to Syracuse) to pick them. Totally worth it. Am just about to take them off now. (17" tires are not my ideal snow wear) O.
Look under the panel near the driver's knee. There should be a black push button/switch on wires. When the system loses power via a removed battery, once installed the security system will act up. If she has a remote, that should fix it. Go to cars101.com and look under programming remotes. Otherwise just push the button and hold it while cranking. The system will randomly flash and or lock and unlock the doors until the button is pushed. Without the remote it will act up again, unless you disable the security system. O.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
Woodruff key
ocei77 replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Advance Auto, NAPA and others sell packs of them. Never measured. O. -
Knock sensor
ocei77 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Knock sensor. By both I hope you mean O2 sensors. Do the front first, clear codes. Bank 1 sensor 1 is the front unit, sensor 2 is the rear. O.
