ocei77
7
Everything posted by ocei77
The grill has pop it type fasteners. If yyou remove the radiator supports the fan assembly will tilt away and you can squueeze the locks to release. There are 4 on the of the grill and two in the middle. These you hope they come out easily, but most probably these tabs will break. There is a ten mm hidden there. Is a total of 4 10's that have to be removed. O.
Engine swap
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You have your answer. Change the crank and cam sensors. O. -
A small clarification. PZEV did not start in Ca. Ca had the strictest emissions standards and Subaru's response was the PZEV. This started in 04 and early 05, so this is the odd header design that Subaru first used. Other mfg have different names. It's the CA emissions std that other states have adopted. O.
Tooth Count ej25
ocei77 replied to rrgrr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You don't by any chance have installed the old style tensioner do you? All the slack is out? The 40.5 is the tooth count you should have from the crank sprocket mark. O. -
The "easiest" route is from the bottom. But the last swap I did about 2 mos ago, no matter how I tried. the swivel would always be at the wrong angle and locked up preventing me from turning the bolt. I have pulled axle pins before, but this time I did it from above both off and on, and yes it was an auto. O,
You probably have 5! The 04 and early 05 was the first pzev engine for the CA emissions states. As such they borrowed the header design from the H6 engine. You should have two equal length headers each with their own cat and a cat after the Y. The first 2 cats have 2 O2 sensors and the 3rd one has 1. O.
EJ25 DOHC Engine
ocei77 replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
As Matt167 stated. Heads, intake, and everything related to ignition timing from your DOHC to the SOHC EJ 251-253 from 01-05. Need to swap the dipstick tube also. May have to change the flexplate. Should be no codes, for the ecu will only see what your 98 harness tells it. Any codes you may get will not be related to the swap. If your new block does not have egr, there is a workaround. Do a search for how. O. -
Radiator cap?
ocei77 replied to scatgo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Make sure the hose in the overflow bottle is cut at a slant so that it doesn't just suction to the bottom. There was a TSB about this a while back. O.
