ocei77
7
Everything posted by ocei77
Once twisted the circuit is always complete. It will work regularly whenever the battery is disconnected again. I replaced the toggle switch on a 98 Impreza, but the female driver had to move her seat up all the way, constantly hitting the switch. I just twisted the ends and removed the toggle. No more problems in this area. O.
the torx screws on the tranny hump require the security type. vise grips will work. Careful when you remove the control cables. There are small e clips which are easy to lose. Take your time and plan on an all day affair. Don't drop the steering column until you absolutely have to, it will be in the way. There are hard to see screws on the left of the panel underside. Use your fsm and count to make sure you have them all. O.
Direct swap, no need to replace intake. You will need the Y pipe from the 2.2 to match the heads. If cars are auto, you also need to swap the 2.5 flex plate onto the 2.2 block. Replace the separator plate on rear with the updated metal one. Do search for swap and you'll get a lot more info. You can also download the fsm for future reference. If you don't know the engine history now would be a great time to do the t belt and idlers. If over 200k, do the water pump too. O.
That is what you have to use. The first two are generally a little tighter. Follow the sequence in the fsm, break each about 90 deg. then go back and finish unthreading them. Once the tension is broken and you make the first few turns, if you have an impact wrench it will make the unscrewing easier. They are loooong threads Do not use the impact to do any type of final tightening. Just enough to seat or unthread. If you've mistakenly completely unthreaded a few, just insert and torque to about 50 ft lbs, then break the others. O.
As p73 said, the axle stub is in the wrong position. If the tranny side did not move, just make sure the dimpled side is where you are inserting the pin. If you removed it from the top, insert it from the top this will maintain the hole alignment. I once did what you are doing and couldn't figure out why it didn't go back in. Time and frustration got me and I temporarily inserted a nail and bent it. Thought more at length later and rotated the stub and voila! I just took a 12 inch 1x1 piece of wood, drilled a hole an inch down a bit smaller than the punch and tapped the punch into it. Easy, firm and disposable. O.
Use a strut compressor which has the lock pins. You can do a rental from Advance Auto/ similar shop and they will refund the cost when returned. These are completely safe. I dropped a compressed unit and noting unusual happened. Knowing I was going to use them again, I purchased a pair ($60 from Advance) and have been completely satisfied with the decision. O.
when replacing the struts, you will have to cut the tab that secures the brake line in order to remove it. You will also have to notch the new strut to accept the clip (or zip tie) to attach the brake line. Unless you feel like disconnecting all the lines and have Soooooo much fun bleeding the system. O.
Oil Pan Leak
ocei77 replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Also, the washer is direction specific. The larger flat side goes to the nut. If reversed, it will leak. O. -
IIRC the Calif. spec belt has the 105k change interval and was cheaper than the Fed spec unit which had a 60k change interval. No other differences outside of construction material. O.
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
