ocei77
7
Everything posted by ocei77
If you don't have it, download the FSM. Search the sticky above for FSM. When you look at the crank there should be a group of 5 letters, ranging from A to maybe D. Each letter represents a tolerance range. Attached is the engine spec sheet JIC. A is std. ,B is .03,C is .05 and D is.25. Should also be a group of 4 letters for the rod bearings. Haven't been able to decipher those. Unfortunately cranks are not generally all one size from the factory. You can buy separate main bearings from Subaru, but not rod bearings. If it is within your budget, would be easier to have them all machined to the same size. O. general description.pdf
- 4 replies
- rodbearings
- mainbearings
(and 1 more)
Tagged with:
The 99 2.2 uses an AFR O2 sensor in the front. If this is going bad, your mileage will suffer. First tho, do the usual. Plugs are a must. Then see how it does. O.
- 14 replies
- Bad mileage
- 1999
(and 2 more)
Tagged with:
95 FSM says 2,1 psi for activation of light. Data in lubrication section on specifications page.(last pdf in section) O.
- 21 replies
- schematic
- electrical
(and 2 more)
Tagged with:
I've never heard of anyone removing the freeze plugs just to remove coolant! Why bother? Any small amount that remains is still antifreeze. Buy a radiator flush kit from your auto store, remove t stat from housing, reattach and add a garden hose, if you have somewhere safe for the water to drain and not create a hazard. If not, then just add through upper radiator into the block. The weeping of this series of EJ is a known issue. Subaru just says to add the "conditioner" (aka stop leak) and monitor your fluid levels. O.
FSM's
ocei77 replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No, another moderator moved it to the FAQ. I didn't realize just anyone could add to a sticky. If you will note, this was originally posted on 12/12/13. O. -
LGT with vented rotors, require 16" rims. Brackets etc will fit, but new pad type also. Go to http://opposedforces.com/parts and after you get to the part number, click on it then go to usage information. It'll tell you what other cars used that part. Even then, sometimes there is a different part number because of a mfg change, but still interchanges. Try your local auto store and see what they have for interchange. O.
Continually see requests and needs for fsm"s. Here is what I have. 1990,1992,1995-1997,1999-2000+ www.main.experiencetherave.com/subaru_manual_scans 2005,2008 and 2009 http://people.csail.mit.edu/ilh/vacation Tech info from Northursalia www.northursalia.com/techdocs/pdf/pdf.html Parts Catalog www.opposedforces.com It would be great if the moderators would make this a sticky and also a sticky of the engine swap info. I am sure Johnegg,grossgary and others have cramps in their fingers from rewriting the same info over and over. O.
Just check point of origin. Some are shipped from outside the US and will take a while to get here. O.
- 11 replies
- subaru impreza
- knock sensor
(and 1 more)
Tagged with:
