ocei77
    7
Everything posted by ocei77
  1. It is the engine coolant by[rump roast hose. Duct tape, i woudn.t chance it since you are in a safe place. O.
  2. 99 was a transition year. IIRC they went from a three part bulk harness to a two harness unit. The temp sensor also changed location and connector So you will need the harness that matches the body and that intake. The ect can be swapped as necessary to match.
  3. Don't know which axle they were on. Just that the installer could not get them to balance they were so out of round. Placed both on rear until I changed them. Seems like wheel sensors threw an ABS code as it couldn't figure out what was what. The ABS fault after a time put it into limp mode. See DTC 0500 for vehicle speed sensor O.
  4. Update!!!!!! Earlier fixes were just coincidental, Issue returned and after more research, the car was going into limp mode and the fuel was being cut. Could not figure it out. Recently had an unusual flat where the tire had to be replaced. Bought a new set as they were at the end of their life anyway. Two of the rims were so out of round that they could not be balanced. Finally got two new rims of same style and switched the tires. Issue solved!!!! It seems the wheel sensors told the ecu that things were off and put into limp mode. In other words balance the tires. Hope this helps the next person.
  5. The e brake is held on by a u clip on the back side where it goes into the bracket. Loosen all the interfering bolts and the 4 14mm that hold the hub on. Once all that is loose the hammer will knock it loose and it will basically fall off. You will find it extremely hard to press a new bearing on the car. If all this is too much pay someone to replace the whole spindle. O.
  6. Replace the hub. RockAuto. Once you remove all the interfering bolt attachments ( lateral link, strut mount, sway bar link upper transverse link and axle nut)there are four bolts that mount it to the hub. You won't need to remove the parking cable. A hard rap should dislodge the hub and if you want to replace a rusted backing plate, now is the time. Of course you have to remove the caliper and bracket. Once you look at it, it's not as hard as it sounds. Just time consuming. Jack the car as high as you can and use stands. Spray with pb the night before if you can. You really need an impact gun, but you could get by w/o it. Definitely 1/2' drive Need 19mm sockets and wrench, plus the 32mm for the axle nut. Break that loose before you raise it, unless you have a heavy duty impact. Plus14, 17 ,10 and 12mm sockets. A long extension to pass through the outer part of the spindle to get to the caliper bolts. Don't forget the anti sieze on install O.
  7. Highly unlikely that the pinch welds on such a recent car have rusted through, but any thing is possible. There is the small skid plate that attaches to cross frame behind the motor in the front and the rear differential support in the back. Both are centrally located so you can lift a set of wheels at once. Then place the stand on solid parts of the frame. Look at your manual for the std jack points O.
  8. No fuel. Not at the fpr itself but on the line that connects to the metal end of the intake.
  9. Update. Thank you to Lucky Texan, it was indeed in the vent line. There was a crack in the hose at the barb fitting. Cut it out and all is good. Thanks again. Who wouda thunk it?
  10. No wetness, but there is a gas smell in the compartment. Which quickly dissipates On the 05 CA model there is an FPR (modulator) on all three fuel lines. Notice from a cold start on medium throttle, I get pulsing, for a small time, until the car warms up Have access to FPR's at local yard from an 05 and will look into replacing 2 of them. Will advise.
  11. Only code is an evap one. Not related obviously. Didn't get chance to swap o2's. If friends garage is open tomorrow, will get a chance. Will check timing. Non AVLS. Will advise. O.
  12. Update: Am finding that the short term fuel trim on Bank 2 is off. Running lean, Numbers in the negative. Had a spare and replaced the upstream O2. No change. Will swap the downstream from one bank to the other and see if the bad trim follows. BTW this is the late 04 and early 05 which has 5 O2 sensors and the modified H6 exhaust to fit the 2.5. Will advise. Still looking for suggestions.
  13. 05 2.5I, MT. Recently starting getting inability to rev past 4K. No stumbling or anything else until I get just past 4k. Occurs in any gear. Have access to an Autel scanner, but so far can't pin it down. Does not seem like fuel starvation, but what do I know? Nor like a partially clogged cat. Unplug the TPS at TB ( DBW). After a few minutes of learning, it revs to redline, but after 5 minutes or less of actual driving, it starts again. No codes, so am at a loss. Suggestions? O.
  14. Run it until the low fuel light comes on. Use a transfer pump to get most of balance to other side. Use something firm like a hard rubber sanding block with the curved side down and hit it with a stick. Should be able to get most of it out. O.
  15. That is correct. FSM:Subaru Factory Service Manuals (FSM) - Every Model - USDM/EU (sl-i.net) O.
  16. The 79mm is not the length of the rod, but the stroke. All 2.5 engines have a stroke of 79mm and a bore of 99mm.Measured from center of king pin to center of shaft at either tdc or bdc.. That's how they get the total volume of 2498cc Piston design (placement of king pin) effects stroke. So if the piston centers are different the rod will be different to make the CR the same The cam qty does not change that. Only the deck height.
  17. Just clean it, its there. That's the power steering line in the pic The pistons may be a different shape, but all the 2.5 cranks ( other that the ej25D , have 52mm journals) with thrust on #5. The rod length is the same also (79mm) IIRC. look at the FSM on the specs page. The answer to your questions are yes. The blocks are the same. Use the old heads. O.
  18. Pull the crank and have it checked. If its a bottom end knock then more than likely a rod bearing is gone, so will damage the crank. If salvageable use it with the 01 pistons and a rod to replace the broken one. The 01 block has to be cleaned thoroughly to make sure there are no metal pieces lurking in the oil passages. Change the piston rings, rod and crank bearings, and all timing components( getting quality components. Gates is no longer a reliable mfg) Download FSN here:Index of /Auto/Japan/Subaru (jdmfsm.info) O.
  19. For future reference. opposedforces.com/parts The 93- 98/9 uses the same assembly. Better off pulling one from salvage car, O.
  20. 2 2x4's across two rafters will work, or even a 4x4 as close to where there is a truss as possible. They don't have to be much longer than the span they have to cross. If you can, secure the ends to the joists. The weight will be where the pulley is, so the length won't matter. Don't even remember the quantity of engines I lifted with just a chain through my house garage ceiling and a come a long. Just don't try to do an engine and tranny in one piece!!!!
