ocei77
7
Everything posted by ocei77
can't find a ref pic of rear of block, but unless you see a lot of oil, more than an inch wide from the rear main, I'd leave it. The other plate is the access for wrist pins. there is an O ring in there. Some replace the O ring, others just ultra grey the unit. The upper left of the new metal plate should have an arrow next to bolt hole. This is where the special screw goes. O. Found a link. Engine is DOHC, but the rear is the same, just scroll down. http://www.rs25.com/forums/f105/t74366-tearing-down-ejxx-block-pictures-head-removal-splitting-block.html
Option. Locate an 04 or 05 with Ca. emissions. This pzev used the exhaust headers from the H6 3.0, but with flanges to match the 2.5. Pic below is of an 04. O.
Once the caliper bolts are removed there are two 17mm bolts that attach the bracket. PB and you may need a breaker bar. Make sure you use 6 pt sockets. You can hang the caliper from the strut spring. Rotors may be stuck, but gentle tapping should free it. If not, there are two threaded holes (8X1.25). Using a two inch length bolt will be enough to force the rotor off. Anti seize bolts and the center ring of the rotor on install. O.
EGR pipe
ocei77 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you remove the egr unit, you can remove the studs that go into the IM and will give you working room.At least for the top one. That brass nut LOVES to round off. Everytime I have to do one it's an adventure. Wound up using the above procedure and a pipe wrench to get that one off. Didn't have to do the lower(lucky me) as I was only removing the IM. O. -
Don't know the actual differences, however you can reverse lookup and check. If you click on a part in opposed forces, you will then see a usage info link. Clicking that will show all models that part fits. Otherwise you can go to a Suby vendor website and go to the particular part and without using any filters, you can see the part number for all Subys, then you can narrow your search. O.
99 Forester has the 2.5SOHC and as such the HG's will leak externally in this series. SOA's "fix" was their "conditioner" (read stop leak). Will last an indeterminate mileage n this condition. Just watch coolant levels and signs of seepage. Unless you have nothing "better" to do, I'd leave it alone. I'm retired, so when I pull an engine I tend to do everything, for I have nothing but time and little sense. O.
]Probably pump. Check voltage at pump terminals. If 12 v, then pump is problem Alternatively you can jump pump to battery and see if it works. Easy fix in either case. Can't help with seat tho. Attached is schematic for seat and a link to FSM for your car. http://www.main.experiencetherave.com/subaru_manual_scans/ Power Seat System.pdf O.
