ocei77
7
Everything posted by ocei77
Suby oil pressure mil is set too low for comfort.3/4 psi IIRC. We can only keep a check on our level. If the level is good and you are getting flashing, then something may be up with the pump/the sensor.. In case you didn't find it, the oil system section starts on p 341 of the pdf I sent a link to. O.
- 21 replies
- schematic
- electrical
(and 2 more)
Tagged with:
Need to post more info. 2.5/3.0. In either case, here is a link to 2008 fsm. You'll have to look. Its a big pdf (5800+ pages), but it has all models. http://people.csail.mit.edu/ilh/vacation/ O.
- 21 replies
- 1
- schematic
- electrical
(and 2 more)
Tagged with:
After the pinch bolt was opened a little, used PB, then put castle nut back on but not all the way tight, and finally a 4 ft spoon bar. Pryed it right out. On a previous ball joint,the arm pried down, so I used a chisel at an angle on the BJ to break the rust loose, then reattched castle nut some then pried. O.
Breaker bar against the frame or against the ground and blip of the starter has never failed for me. O.
- 7 replies
- EJ22
- Crank Pully
(and 1 more)
Tagged with:
Timing Belt
ocei77 replied to Reggie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
IIRC it has Kevlar in its construction. O. -
There are 2 or 3 bolts that attach the window frame to the regulator. Sometimes one of these begins to back out and causes similar symptoms. You have to pull the door panel to check. They are either 10/12mm bolts. You can lower or raise the window until the bolt appears in an opening. In one case the bolt hole wasn't directly in an opening, so I drilled a 1" hole though the sheet metal so I could reattach. O.
egr pipe size
ocei77 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Remove the EGR valve and gasket. Use two nuts. The 12's that came off will work. Use a wrench on the inner jam nut and you can turn the stud out. This will give you room to use either vise grips or a small pipe wrench. PB the copper pipe well . This won't strip the nut and gives you the oomph to pop it loose. Heat won't hurt, but I had to resort to the above method to get mine off. Didn't have to remove the bottom one in my sitaution, but I'll cross that bridge when I get to it. O. -
What sealant?
ocei77 replied to samm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Everybody has their preferences and there are specific times where I prefer one or another. When there are large gaps or very uneven surfaces, I use ultra grey or the red hi temp. All other times I use anaerobic. Mainly because it doesn't set up in air, and if you have to delay mounting or remove the part, it doesn't make a mess and can just be attached. O.
