ocei77
7
Everything posted by ocei77
Although you have more tools than I ever will, usually the wrist pin is frozen in there and it takes a lot of work to get it out with the homemade tools. On my 2nd excursion, after removing the circlips, I used a foot long 7/8 in wood dowel as a drift and knocked it out easy as pie. Worked well on installation too. O.
Had same issue. In order to get the boot on, you'll have to remove axle anyway, as the 2 piece boots will eventually fail. If the joint is still full of grease, you should be ok. It not, might as well replace the axle. 5/16 punch inserted into a scrap of wood about 18" long,so you can knock out pin from above works well. Do search for axle removal and you'll see caveats involved. O.
1) Clean the valve cover area and hope its comng from the cam seals. If not sounds like either a separator plate or rear main. The latter two will require an engine pull. Add some oil stop leak and it will give you more time to resolve issue. 2) tune up issues most likely. Plugs,pcv valve,etc. Need more maintenance history, especially t belt etc. Am sure this will have to be done also. 3) Probably a complete R&R for brakes needed. Check to see if pads are gripping rotors (ie :clean rotor surface). The rear drums are a PITA. New shoes (at the least). New fluid and bleed FRt,LRr,FLt and RRr. If you can do the work yourself, it's time and some money. If not, there's going to be a major influx of $ if you have to pull the engine. Am sure others will add and/correct. O.
EJ253 with 85K. Oil replaced religiously(dino) at 3000-3500 miles. Spun a bearing 3 weeks after an oil change. Only possible contributing factor is I went in for the ECU emissions reflash. Within three weeks my second cat was clogged. Gutted 2nd cat,new front O2and bearing went within a month afterwards. O.
Not sure if i understand entire post. If pedal goes to the floor or more than 1/2 way before grabbing there is still air in the line. Rebleed in a cross pattern. If pedal goes and holds, but very little stopping power, more than likely your calipers are sticking. Are the surfaces of the rotors where the pads touch shiny all the way around?, probably not. Remove the pins on each side (note that they are different top and bottom, and that one has an o ring on it). Clean and lube, then replace and see if this helps. Then adivse. O.
Salvage? 05-07 are the same. 1stsubaruparts, lists for $255 plus 10% shipping. I would personally remove unit and rig something to blow warm air through it to get rid of as much accumlaled fuel as possible.or, even just leaving it out in the sun. Unless I am wrong(someone will correct me if so) its only a charcoal canister. http://opposedforces.com/parts/forester/ According to Opposed forces there are two types of canisters for the 07. Later production of Nov on is a different type O.
If you go here: http://www.main.experiencetherave.com/subaru_manual_scans/2000+_Legacy_FSM/ Go to wiring section. It starts with the 4 but half way through goes to the 6 cyl. section. Hope this helps. For future ref a lot of the '02+ manuals are the same. Here's an H6 but couldn't find AC in it. http://bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=211&sid=e107124d83905c4fb07de0b0ca7999c9 O.
