ocei77
7
Everything posted by ocei77
The head and exhaust are modified EZ30 units. The big problem is that the EJ259 had 3 cats and 5 O2 sensors! O.
- 29 replies
- 1
- short block
- single port
(and 3 more)
Tagged with:
The 96 2.2 is non interference. If the OP doesn't know how to fill and properly burp the system, it will continue to overheat. Do search for burping the system. If you can get it pressure tested, that will determine the source of the leak, but from what you've said it again leads to the radiator. With this mileage, you might as well replace the hose from the water pump that feeds the water bypass pipe (the pipe that feeds the throttle body). O.
Struts
ocei77 replied to Sherman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
RockAuto lists different KYB units for rear struts. O. -
Coolant leak
ocei77 replied to jonbfish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
check the elbow hose that goes from the pump to the water bypass pipe that feeds the throttle body. O.
