ocei77
10
Everything posted by ocei77
No wetness, but there is a gas smell in the compartment. Which quickly dissipates On the 05 CA model there is an FPR (modulator) on all three fuel lines. Notice from a cold start on medium throttle, I get pulsing, for a small time, until the car warms up Have access to FPR's at local yard from an 05 and will look into replacing 2 of them. Will advise.
Update: Am finding that the short term fuel trim on Bank 2 is off. Running lean, Numbers in the negative. Had a spare and replaced the upstream O2. No change. Will swap the downstream from one bank to the other and see if the bad trim follows. BTW this is the late 04 and early 05 which has 5 O2 sensors and the modified H6 exhaust to fit the 2.5. Will advise. Still looking for suggestions.
05 2.5I, MT. Recently starting getting inability to rev past 4K. No stumbling or anything else until I get just past 4k. Occurs in any gear. Have access to an Autel scanner, but so far can't pin it down. Does not seem like fuel starvation, but what do I know? Nor like a partially clogged cat. Unplug the TPS at TB ( DBW). After a few minutes of learning, it revs to redline, but after 5 minutes or less of actual driving, it starts again. No codes, so am at a loss. Suggestions? O.
The 79mm is not the length of the rod, but the stroke. All 2.5 engines have a stroke of 79mm and a bore of 99mm.Measured from center of king pin to center of shaft at either tdc or bdc.. That's how they get the total volume of 2498cc Piston design (placement of king pin) effects stroke. So if the piston centers are different the rod will be different to make the CR the same The cam qty does not change that. Only the deck height.
Just clean it, its there. That's the power steering line in the pic The pistons may be a different shape, but all the 2.5 cranks ( other that the ej25D , have 52mm journals) with thrust on #5. The rod length is the same also (79mm) IIRC. look at the FSM on the specs page. The answer to your questions are yes. The blocks are the same. Use the old heads. O.
Pull the crank and have it checked. If its a bottom end knock then more than likely a rod bearing is gone, so will damage the crank. If salvageable use it with the 01 pistons and a rod to replace the broken one. The 01 block has to be cleaned thoroughly to make sure there are no metal pieces lurking in the oil passages. Change the piston rings, rod and crank bearings, and all timing components( getting quality components. Gates is no longer a reliable mfg) Download FSN here:Index of /Auto/Japan/Subaru (jdmfsm.info) O.
2 2x4's across two rafters will work, or even a 4x4 as close to where there is a truss as possible. They don't have to be much longer than the span they have to cross. If you can, secure the ends to the joists. The weight will be where the pulley is, so the length won't matter. Don't even remember the quantity of engines I lifted with just a chain through my house garage ceiling and a come a long. Just don't try to do an engine and tranny in one piece!!!!
The head and exhaust are modified EZ30 units. The big problem is that the EJ259 had 3 cats and 5 O2 sensors! O.
- 29 replies
- 1
- short block
- single port
(and 3 more)
Tagged with:
The 96 2.2 is non interference. If the OP doesn't know how to fill and properly burp the system, it will continue to overheat. Do search for burping the system. If you can get it pressure tested, that will determine the source of the leak, but from what you've said it again leads to the radiator. With this mileage, you might as well replace the hose from the water pump that feeds the water bypass pipe (the pipe that feeds the throttle body). O.
Struts
ocei77 replied to Sherman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
RockAuto lists different KYB units for rear struts. O.
