ocei77
7
Everything posted by ocei77
What's your wrenching experience?
ocei77 replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
Do a search on engine swap or clutch replace. Should be lots of info there. Use this link for fsm http://www.bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=171&sid=41e07798e172c3bbdbc67d2850953ecf Take pictures and use Ziplock type bags for any loose items. Take your time and label things that need to be connected that are not apparent. Cover the front of the ac radiator, so that you won't dent it as you lift motor. I have replaced a clutch without completely removing motor but not sure if you can. Have fun. O. -
torque bind
ocei77 replied to garylov's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
meanwhile, change the tranny fluid. O. -
Not entirely true. Subaru's AWD system and computer checks the revolutions of each wheel and adjusts accordingly, since it appears as slip. Subaru states that the circumference tolerance is 5/32 of an inch. Running larger than this will eventually damage the center differential. You can't just put a new or used tire on one wheel and ignore this. This why some when forced to replace an expensive tire,rather than buy a set they have the new one shaved to match the other 3. O.
Hello!
ocei77 replied to Sabaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Can be done without removing engine, But, it's a real PITA. The pasenger side is fine. The driver side is the kicker. Remove the washer bottle. Disconect and tie out of the way any lines that will be in the way. The EGR line needs a 17mm wrench. Flare type would be best. Removing the valve cover would give you more room. The hard part is keeping the bolts from sliding down and preventing alignment. Finally tried paper towels, so the bolts would'nt slide but so far. Worked. Double check all your unplugged connectors. O.
