ocei77
7
Everything posted by ocei77
The tensioner has to be compressed in a vertical position, to make it easy to understand. I used a c clamp,and just hung it from a wire in between turns as I did other things. There is a small hole that goes through the tensioner. Find an allen key or nail that will go completely through it. Once compressed put the tool in and do not remove until after the belt is reinstalled properly. O.
While the store manuals, may be crap to some, they are a lot better than nothing and worth the $20 IMO. Of all the talk, no one pointed a link to OP for an online FSM! If he works on BMW's he can do a Suby. I don't have the link to the FSM and the files exceed the size limit. If no one points you to link, PM me with your e mail and I will send you the 2.2L manual. O.
+1 on riding the brakes. Can't be quiet in regard to oem tho. This will be a never ending debate. There are always cases where one is better than the other. I do my own mechanicals and I use Hawk HPS pads. Better initial bite and the longevity is there. Put ATE super Blue in as fluid and SSlines for a better feel.
how can i tell if 2.2 engine is interference motor or not
ocei77 replied to deepbluehawaii's topic in Subaru Transplants
You can tell by looking at the valve covers if you don't know build dates. The phase I have horizontal lines and Subaru in the cover. in addition the spark plugs are right above the valve covers. The phase II valve covers are smooth, no logo and the plugs go through the valve covers. Can't remember from whom I got the info to give proper credit. I have a phase I BD O. -
96 2.2 motors
ocei77 replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There are so many variations that it is boggling. (at least to me) Go to NASIOC, conversions forum and search frankenmotor. O. -
96 2.2 motors
[ ala frankenstein O. -
96 2.2 motors
Where you mix and match heads and blocks from ej22 and ej25 engines mostly. O. -
Don't know what exactly you are looking for, but $2500 for a 32 year old car is a little bit much to me. You can do better O.
I rebuilt my EJ 253 from an 07 2.5I legacy. Used Rockauto and AutoParts Warehouse. APW website is just a pain to use, but, they had better prices for the seals and gaskets. Only replaced T belt not pulleys etc. Car only had 85K. Still usable but didn't want to go back in just to do it. I reused the OEM water pump gasket since it was aluminum. Bearings find someone that has ACL. I let machine shop get mine. Most head bolt sets are in a group of 6. Check with source as to how many are included. Don't know if you've done a Suby engine before, but a few tips. there is a bolt that goes through crankcase behind water pump. A great place to use as a fulcrum point to lever that lower crank pulley in so that the bolt holes line up. Also make sure the oil pump is orientated correctly before putting sealant on it. Since it is driven by a flat surface on the crank. Don't forget to pull the pin from hydraulic tensioner! Have fun O.
