ocei77
    10
Everything posted by ocei77
  1. +1^ and the rest of your fluids As a precaution I keep an alternator belt in the car and basic sockets and wrenchs You can drive about an hour w/o one, but then I would probably be in the middle of nowhere. O.
  2. Are you trying to do a valve adjustment or reinstall T belt correctly? The above info is correct for T belt install. What engine and year? O.
  3. The diagram just is just telling you what colors the lead wires are. You missed the optional arrangement note. ECU is under carpet in passenger footwell. O.
  4. Perplexing. Although the coil and plug wires are new, try anyway to see if you are getting leakage at the terminal. At night or in a dark garage, let vehicle run and when it stumbles, spray water with a mister around the connections. Check voltage at coil when it stumbles, one plug at a time and be careful! Again, check your sensors won't take but a few minutes. The ignition signals go from the sensors to the ecu and then back to plugs. Get FSM and go to the 300 series of DTC's there are 4 pages of troubleshooting O.
  5. If the timing is off they are not getting the correct signal at the proper time.. Easy to check by removing the timing cover and aligning the crank. If the car is not underpowered, they are firing at some point. Make sure you have continuity and correct resistance between the bulk harness and the injector terminals. There are diagnostics and connector listings in the FSM, which you can download here:http://jdmfsm.info/Auto/Japan/Subaru/ Wiring would be under engine electrical Are you only getting codes 301 and 302? O.
  6. Check the timing and that crank and cam sensors are connected. O.
  7. EJ25D, as stated classic HG failure. But, make sure there is no coolant pooling anywhere on the top of the engine. O.
  8. 2005 Legacy, MT. Put car on lift, grab wheel at 6 and 12 o'clock and see if you get any play. May be no more than 1/4 to 3/8 in. Some of the common diagnostics don't always tell. I had a whine in FR which I first thought was a bad tire. Noise would lessen when the wheel was turned while moving, to the right. Had car on lift, used stethoscope, no discernible difference than FL. Had some play at 6 and 12 which is characteristic of bad tie rod. Replace TR. Still no change. Looked harder at axle while lifting and could see the housing move!. Replaced hub and all is now good. The noise could not be duplicated it seems unless the wheel was under load. If you plan on replacing, spray PB on the caliper bracket bolts and the 4 bolts than secure the hub.. You don't need a puller. Once the 4 bolts are removed you can tap it out with a hammer. O.
  9. To answer number 4. I find it easy when I first make sure the far side criclip is in. I use a 8 in long 3/4" wood dowel as a drift. Once the rod is aligned just tap the oiled pin in until it bottoms out on the circlip. Install the front circlip and rotate to the next. O.
  10. If you can do the work yourself, it won't be too bad, as long as you have an open space to work, even if outside. Rent or make an engine lift. You will need an engine stand to work comfortably. You can machine the heads yourself. Work on calm days and if necessary work inside a tent. Challenging, but it can be done, as long as you have space. FMS here:https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-(FSM)-Every-Model-USDM-EU O.
  11. ^+1 It's not the belt, if the timing is correct, something is disconnected. In addition to sensors, check the IAC hose, (the 1" dia. one) that goes to the throttle body. If that is not connected it won't start either. O.
  12. ^+1 Jack it up, remove the calipers, rotate the wheels, use a c clamp or similar to push the pistons back, then remount. Push brake so you have some stopping power , then try the gas again. O.
  13. If the parking brake was not left on and it is indeed the front, then it is probably rust buildup or similar. Does it roll backwards? Make sure there is nothing in the way and apply gas until it breaks free. O.
  14. The gas filler tubes are generation specific. Buy the OEM unit. It will probably have a small vent tube somewhere on it. O.
  15. FSM available here: https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-(FSM)-Every-Model-USDM-EU If the final drives are the same then you're good. The MT Forester has 4.111 The AT is 4.444 The Impreza (RS has 2.5L) the MT is 4.111 and the AT 4.444 The 2.2L tho has 3.9 on the MT and 4.111 on the AT. O.
  16. No idea til you found out what's wrong. SubaruPartsFor You, lists a complete Turbo short block for $2030!! O.
  17. You will need a new short block at the least probably. Rod knock means having the block checked for journal roundness and line honed if need be. A new block is the cheaper alternative You will then have to have the turbo checked to see if its still good. If it was a cheap and/or easy fix, it would've have been done already. O.
  18. If the inlets and outlets are in the same location, then yes you can. You may have to run hose for the AT lines but that's all. O.
  19. Plugs are cheap. Change it. Sorry but our gap is measured in mathematical units, not blade bits. lol. .044. Move the wire from three to one. If the code comes back on one, you know it's the wire. Very seldom a coil with only one cylinder.
