ocei77
7
Everything posted by ocei77
You seem to have two concurrent but different issues. The O2 sensor in the rear may need to be replaced, but first go through the diagnostic listed in the FSM . http://jdmfsm.info/Auto/Japan/Subaru/ You will need to remove the end covers and blow the main cover out thoroughly with air. There are still pieces floating around from the crank pulley. O.
Motor swap
ocei77 replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes you can. Swap heads, Intake manifold, crank sprocket, and the crossover pipe as the harness connect for the ECT is in the front and won't reach that on the earlier block as that ect is in the rear. Of course you have to swap the flywheel and timing belt guide over. Take your time and use the HG designed for the turbo engine. O. -
O2 sensors 1996
ocei77 replied to YOWZA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
^ Unnecessary. It had to come off whether a new one was to be used or not O. -
05 Legacy 5MT 225K Wanted to change F rotors to slotted units I had. Done. Reassembled and out of nowhere, no brake pedal!! The brake lines were not opened and there are no leaks. Wound up replacing both calipers as the bleeder screws broke off. Bled, still no pedal. It works, but goes all the way down. Seemed like classic master cylinder failure. Replaced master cylinder. Still no pedal! All four wheels have been bled, the new master was bench bled before installation. What next? Bad ABS HU, from out of nowhere? O.
lost fob Ms
ocei77 replied to pattimaggiora's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Disconnect battery, now you can work in peace. There should be a small button on the lower left trim panel down by your knee. If not look under the panel and it may be taped up. Hold in while you start car. Get key fob from Ebay and go to cars101.com to the section on programming remote, O. -
O2 sensors 1996
PB or Kroil. Make warm first. vise on O2 bung ( you can buy replacements cheap if needed), and wrench on sensor. O. -
If yours are like my 05 wagon( no reason it shouldn't), it's a fixed nut. No reason that 12mm should break. But Murphy rears its head at odd times.. Poly bushings are better and don't forget the lube. O.
- 1 reply
- 1
