ocei77
7
Everything posted by ocei77
If the 05 is the CA emissions as stated above you would have to swap the cylinder heads to make it work. In either case you need to swap the intake manifold as the 05 is DBW. Swap the crank sensor, and the driver's cam sprocket. You will probably need to swap the water crossover pipe as the temp sensor is on the front in the 05 and the harness won't reach to the old location on the back and the connectors are different. O. .
Unusual to have problems with Bosch as they are the originators of O2 sensors(but this doesn't make them immune from issues). I have replaced in a 98 IOB and a 97 Legacy with Bosch and never had issues. Denso, NTK and Bosch are what I usually recommend., all of whom have been oem suppliers at one time or another. O.
Check with supplier. I just had to return a Sachs clutch for the opposite reason. My replacement (from another vendor) was in the same box and part number but had the correct (smaller) bearing. In addition the pressure plate was @ 1/2' to small in diameter and would not hang on both pins. I have an 05. O.
get FSM here:http://jdmfsm.info/Auto/Japan/Subaru/ Only remove the outer circlips. Use a thin stiff rod and you can snake it past the opposite rod and tap out the king pin. ie: past 3 and tap 1. 4 and tap 2. Make a drift out of 3/4" dowel to install. The block has markings to say whether the piston is an A or B. Spec sheet gives dimensions. Put pistons back into cylinder they came from. Make sure piston is installed with dots or markings facing the front of block. O.
Should be no problem. To check see:http://www.rimsntires.com/specspro.jsp O.
- 1 reply
- wheel offset
- offset
- (and 4 more)
Need Advice to buy
ocei77 replied to Cam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Bank 1 is the front sensor O. -
Need Advice to buy
The p420 is generally a benign code that usually requires replacement of the front o2 sensor and or is the result of an exhaust leak. Rarely but sometimes is needing a cat replacement. O. -
Hood style
ocei77 replied to Turbolaggin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No. It has to be a legacy/outback from the same generation. ie 96-99 O. -
This should help •Yellow - 12V Battery / Constant •Red - 12V Ignition / Switched •Black - Chassis Ground •Black / White - Factory Amplifier Ground •Blue - Power Antenna / Factory Amplifier Remote Turn On •Blue / White - Factory Amplifier Remote Turn On •Orange - Dash Light Dimmer / Illumination •Orange / White - Dash Light Dimmer / Illumination •Orange / Black - Dash Light Dimmer Ground / Illumination Ground •Brown - Mute / Not Used •White - Left Front Speaker (+) •White / Black - Left Front Speaker (-) •Gray - Right Front Speaker (+) •Gray / Black - Right Front Speaker (-) •Green - Left Rear Speaker (+) •Green / Black - Left Rear Speaker (-) •Purple - Right Rear Speaker (+) •Purple / Black - Right Rear Speaker (-) This is the Subaru side Suby radio wirirng.txt
See attached. get full fsm herehttp://jdmfsm.info/Auto/Japan/Subaru/ O.: cylinder head assembly.pdf
- 1 reply
- 1
