ocei77
7
Everything posted by ocei77
The hose goes from the throttle body to the crossover pipe. It acts as a return line that goes from the bypass pipe to the TB. Its designed to keep the throttle body from icing up. Some people in hot climates just bypass or plug them as icing is not a concern for them. It will show up in service procedure for the TB. Use an online dealer part cat. to look up the actual part no. if you need it. The dealer should be able to get it w/o a number. Its on all the EJ22 and EJ25's at least up to 06. O.
There is a 10 amp fuse in the engine bay that controls the dome light and door switches. Probably blown. Check again for codes. O.
- 9 replies
- 2
- dome light
- alarm
(and 2 more)
Tagged with:
If the tires are in good condition, your next option is to change the rubber brake hoses which have gotten soft over time. You can go to stainless steel which will give a greater response. You can change the pads to a good quality semi metallic or ceramic type which will also help. O.
When installed before tightening the two bolts, the tensioner should be forced to the left and held there by a screwdriver, then tightened. There will be a gap until the pin is pulled. You should give it a few seconds to fully extend, then turn the crank by hand two complete revs to make sure all is well and double check the timing marks are still aligned. The belt marks will not be, but the crank and cam marks should, though the driver side may be a 1/2 or full tooth off, which is ok. O.
Every state seems to determine which vehicles will be called truck for registration purpose its own way. In NY Suv's, Foresters and Outbacks are called Suburban. Its own class. .......The law defines a suburban as a vehicle that can be used to carry passengers and cargo. Vehicles that can be registered with the suburban body type include station wagons, sport utility vehicles, hearses and ambulances. The body type code for a suburban that appears on registration documents and records is SUBN. O.
Minivans,SUV,Cargo vans and pickups with a GVW of 6000 lbs or less are called class 1 trucks, even though they have seats behind the driver. The Outback is not called an SUV therefore is not called a truck. They obviously share engines and trannys and the MPG is not that different. For those of you old enough to remember the BRAT. They installed two seats in the bed, so it would not be classified as a truck. O.
What mark are you using on the crank gear? Prayerfully the mark that is embossed on the oil pump that has the sensor attached. The crank key way should then be at 6 o'clock. If you get to this point the pistons are halfway down and will offer no interference with the valves. At this point the passenger side will spin freely, but the driver side will load up as you approach the timing mark. It will sit unless bumped. You can use clothes pins or clamps to hold the belt in place. The lower idler goes on last, requiring some upward pressure as you catch the threads. If the cam pulleys are hitting a stop, STOP. Do not force. You can rotate the crank a little at a time, then the cam pulleys , alternating until they are basically free wheeling. Then you can align as stated. O.
