subaruguru
Status Updates posted by subaruguru
yeah black with red letters kinda faded i could repaint them for you to look like new for 10 bucks more.
Cheers R.
shipping info MO will work for me no pay pal
Robbie Terry
2205 s. 18th st. #70
union gap wa.
98901
Hey sorry a lot of those parts are all gone i do still have the mud flaps, the rubber boot for the shifter and headlight bezzels no problem shipping out of country you pay shipping
thats a puzzler there it could be leaking from behind the torque converter that means rear main seal IIRC. the idle issue might try cleaning the maf and make sure you dont have any vacuum leaks
hi if you are still looking for the heater core parts i have the whole heater assy. from a 1984 brat let me know if you are interested just make an offer.
Cheers R
looks fine from the out side lol and has a gas cap on it so i assume pretty clean inside.
i don't have pay pal but a money order will work my info is
Robbie Terry
2205 s 18th st. #70
union gap wa.
98903
i don't know if it works but it spins freely $20 sound ok? plus shipping
Cheers R.
right where the engine and trans goes together i am assuming you are talking about the bellhousing the only thing i can think of that would leak oil in that area is the "kidney" plate or inspection plate this is located behind the flywheel it will be either metal or plastic and is held on by a few screws they leak all the time on used motors and if the one on your engine is plastic it might be cracked if it is i might have an aluminum one i can sell you on the cheap. This is a simple fix but requires you to pull the engine then the flywheel and remove the kidney plate and use some good high temp silicone.
Cheers R.
Oh ok the hard line is for the EGR as long as the new motor uses the same harness plugs i dont thing you swill have a problem just running the 98 engine as it is. but if that is your problem you might need to swap the intake harness from the old motor onto the new one.
wwmjg i don't make them but if you look up thebeastidrive and his number is under his screen name call him up he is a nice guy and does really good work his name is bill hope this helps.
Cheers R.
so you have the beast now huh thats a neat car i am in the burg too actually i am LJ's (19subaru87) roomie over here on B street I have been working on the 5 lug-SVX-brat swap you should come have a beer sometime and we can all talk car.
Cheers R.
