subaruguru
Everything posted by subaruguru
  1. yeah you can buy a plug for the other side shure they have them at napa
  2. hey i hear ya about the night thing when i had a Weber i just plugged the hole in the bottom of the plate for the breather some people hook it to the cam case vents. the fuel return i just plugged off. the fuel inlet you meen the nipple thing that you slide the fuel line onto? mine had it but i think you can use the one from the stock carb if it unscrews if not go get a 1/4 inch pipe nipple i think thats what it is. Then your good to go.
  3. nice write up i had to do the same thing with my coupe good pics also
  4. looks nice get some engine enamel clear coat or they will corode reall bad after a wile
  5. you could run two pumps with some specail brackit might kill an ea82 but an ej oh the ideas
  6. i have not seen anyone make a coupe into a brat i have seen hatchbacks and wagons but not a coupe. I also like this body style and i would just get a brat but to spendy for a good one and they are to small I am a big guy . and copying kind of yes but i could say the same thing about a lot of people you have a lifted rig right?... see what i mean every one is copying someone one way or another. Rob.
  7. i have a good A/C compressor from an 86 turbo sedan im removing all of the A/C stuff from under the hood you can have it all for 40 bucks tis would be everything exept the lines. i am in ellensburg wa.
  8. Robs is the exception that proves the rule haha
  9. true true we can figure it out later i used a box spring and matress cardbord box to make the rear wall template its gonna look really really good then im gonna get some stacks Chrome stacks.
  10. i would not use them fro structur but they could be cut out of the RX then weld them in to make the window frame for the side windows just to keep the shape i can explain more when im there.
  11. yeah there is plenty to work with and i was looking at it the other day and the back wall will be at a slight angle like we talked about doing. monday is fine if you want any help or just someone to BS with call me up. also how are the B pillars in ur burnt RX.
  12. easy answer for both of them I'm a non conformist oh and i like it haha Rob.
  13. ok so after my thought thread and the broken window it has begun here are some pics to start with and i will be picking up the sheet metal for the back wall. PS all welding on car has been done by B.O.S.S. including but not limited to. Shaved side markers, front bumper, and trailer hitch. Soon to have back wall. Rob. What it will look like. Where its at right now. This is a B.O.S.S. bumper.
  14. no thanks P. Bill and i talked about that and figured with the Wall between the trunk, and the back seats removed it would be really week compared to the coupe.
  15. would have BUT... wagons have smaller doors plus i would need to weld up the rear doors and its just alot of work lol. but it will be cool indeed Rob.
  16. went and checked couldent find one under 200 bucks but the car has been chopped so there is no going back looks good i think. Yes it will be done right.
  17. well soon ment today got bored and teh window getting broke treally PISSED so here you go pics got to this point after 4 hours. what do you think
  18. ok so looks like this might be goin into play sooner rather than later. screwdriver came in contact with on of the rear windows in my coupe not a good sight but no i think i will turn it in to a UTE
  19. [quote=I've been in the same boat plenty of times......... Jeff so you two like to go fishing? hahaha wow i need sleep but i agree with Jeff Rob
  20. not hard at all you need to remove the T belt covers and belts then the cam gear use a seal puller to remove the old and then replace with new ones then put it all back together helped a friend with it easy stuff. i have a set of NEW subaru cam seals 20 and there urs. now if its the cam case itself you need to remove the valve cover then the whole cam case carful not to drop ur rockers they will fall off but can be put back on. then seal with High tmp RTV. worked great on mine. let me know on the seals i have them here in the baggies Rob. just looked there is a crank seal in there too.
