Location
Toccoa
Vehicles
I Love My Subaru
outback96's Achievements
Member (2/11)
10
less than a yr. ago the radiator was replaced with a new cap. the complete assembly came new from Subaru. To my knowledge the Timing belt, water pump, etc. are the original - I have not replaced them. I bought the car 1 1/2 years ago with 173,000 miles on it - it now has 186,000. What website is the best for picking up genuine Subaru parts? What is the Thermostat part number for the 96' Thanks,
Have a 96' Leg. outback with a 2.5L engine auto trans. and 186,000 miles on the car. The other day I was driving in the mountains of N. Georgia when I noiced the temp. raising a little. I never allowed the engine to overheat, I pulled over and ckecked all fluids. The oil was a little low, have slow leak around valve covers, added some oil and coolant was fine. Drove a little further, same deal. The temp. guage never got above 3/4 but would move between normal and 3/4. Again there is no loss of fluid. What has been done already. Less than a year ago, replaced raditor from Subaru and all hoses. rountine oil change the past few days have driven the car around town, enough to have the engine temp. rise to normal, and no movement with the guage now.
hey everyone, been awhile since I've been on, but I have and issue with my 96' Outback's doors. On the Driver side, front and rear, the doors won't stay open regardless of the incline. This problem is driving my wife crazy as she tries to put our daughter in her car seat with holding the door open with one leg and using the other to balance herself. Please help. I figured that there would be a part to be replaced and that I would have to get that from a dealer? Any one know the part # to look for on line. The other issue is with the front breaks. I replaced both pads and drums but still have a squeal -bad. any thoughts.
I need to replace the clutch pack at the rear of my '96 Outback transmission and was able to come across the dealer part number. So I contacted a few local dealers and gave them the part number; one dealer quoted me $144.00 for the part and another one $23.12. What's up with that. I had the dealer confirm that the part number matched the clutch pack that I was needing, sure enough its the right one. Does any one know why there was such a difference in price.
I just replaced the radiator and hoses on my 96 L 2.5. But don't know how to burp the sys. to get all of the air out. What i have done so far. is replace all coolent, started car with radiator cap off. and would add coolent as needed. After no more needing to add. coolent i took her out for a short ride, car responded normal and temp. never got above the normal rang. Is that all there is?
Hey thanks y'all for the great suggestions. As I was looking at the radiator I noticed that there was some dried coolant on the right side. my upper and low hose needed to be replaced anyways, so i removed the radiator and found a 4inch long crack on the right side. My guess is that the crack was just big enough that when the sys. became pressurized that coolant would leak from here and spray over the right side of my engine. Any suggestions on the best way to fix the small crack? Or should I buy a new radiator? thanks
was wondering if anyone knew how to test the coolant sys. for pressure in order to fine a small leak. I was speaking to the shop I normally take my cars to when I can't fix them myself, he said that he would do a pressure test on the sys. to locate where the leak is. Was wondering if there was a real costly tool involved with that, or if it was something that I could myself.
If I may jump in here. I have a '96 outback with 174k on her and just noticed that my value cover gaskets have an ever soooo slow leak. now i've watched this thing and put a cloth under the car and there is no droping at all. i've checked the dip-stick and i'm not losing any oil either. should i replace the gaskets or not? and If I need to, is this something that I can do myself or something that i want to leave to the pros. I have rebuilt engines before, so I feel comfortable doing the work.
sounds like torque bind is what's going on with my subrau. Should i start buying parts and just jump right in with repairing the extension housing? Or should I take it into a transmission shop and let them figure it out? What's my next step. Currently the fues is in FWD and car drives great w/out problems, however, the reason why i got a subaru is for the AWD.
