mrwitty_1
mrwitty_1 last won the day on August 16 2006
mrwitty_1 had the most liked content!
Location
Grafton
Occupation
Firefighter
Vehicles
93 Legacy & 96 Legacy OB
mrwitty_1's Achievements
Member (2/11)
10
Well the new lock cylinder is installed and all is well, no more binding or removing the key while the car is running, that feature had it's benifits...lol The complete job took about 20 minutes including making a special service tool to depress the retaining pin. Thanks for the input from the readers....
I need the forum readers help.. I have to replace the ignition lock cylinder on my 93 Legacy SW it is totally worn out. Is there a easy way to do this ? My repair manuals mention splitting the two half's of the steering column, I have done other vech's that there is a release pin to push on with a small diameter pin and the cylinder will slide out. Please help....thanks
Thanks for all the posts. I found the pdf's last weekend and checked my coil as per. the specs. my secondary points were all with in limits at 21.5 ohms, as for the primary points they were not in limits at 1.3 ohms but the temp was around 20*, winter has arrived here in WV. I didn't not replace the coil because both points 1-2 and 2-3 were equal. Now for the interesting thing, the mis-fire condition has disappeared, over a week and no mis-fire codes. I now think it is a current leak in the secondary ign wires regardless of there new appearance. I'll keep everyone posted. Any suggestions on a dealer or supplier for a set of OEM wires at a good price ? Thanks ....
1996 Subaru Outback 2.5 Auto I have developed mis-fire codes for cylinders 1 and 2. I changed sparkplugs and must say I could not find (like the story of Goldielocks) a socket, extension or combination of both to remove or install #4 plug. I checked resistance of the ignition wires, which appear to be new and OEM and all fell with in specs. I still have a repeated misfire code for the same cylinders. I am leaning toward a ignition coil failure, because 1 and 2 share the same pack, but I'm open to suggestions, I have owned many previous Subs and never had a coil failure, but I guess there's a first for everything. I don't drive this car much as it's the wifes car, but it seems to be in colder temps with-in a few miles of driving that it mis-fires. I have never had the mis-fire when I was driving and can not get it to miss (WOW ...a 2.5 winds tight when pushed hard) Anyone know if all 2.2 and 2.5 coil packs are the same? May try having the fuel injectors cleaned but still lean toward a ign. problem. Thanks for any help.
Sorry I didn't get back lastnight. But here is the info as promised... Car.Tool by United Intelligenee Technology Co, Ltd http://www.enUIO.com I purchased mine off Ebay Here is a link # to one on Ebay now : Item number: 160073082050 I love mine for the $15 and have used it on my Subaru's and my GM's Hope this helps
I also have a cheep code reader in the glovebox of my OB. The wife has it at work but I'll post the model and brand tonight. It was less then $40 off ebay, nothing fancy but will pull codes on all OBD II and also has a small book that describes codes and will clear the codes. As for the P0420, I see it way to much also, time for some O2 senors.
I would bet your looking at a bad blower motor resistor, I've been thru a few of these in my life as a Subaru owner. It is located near the blower motor on the left side, it has two screws in it and a multi-plug wire. Remove it and you will find some springs, A coil also acts as a resistor, thats why there are large and small ones, this gives the different speeds. If you need a quick fix, and it is near then end of the spring, just solder it back to the term, it will be at a higher speed but fuctional. If you get a replacement, resist the urge to operate the blower with the resistor out of the housing, it operates at high temps and the blower cools it. Removing the glovebox allows this to be much easier. Good Luck
This is another torque binding question, I have read the forum on this issue from the time I joined the board and have seen it discussed that some have developed binding after a transmission replacement, I too have now discovered that it was about that time that I developed the same, and now have the strange feeling that the trans and the rear diff are not the same ratio. I did look and find that the rear was a 3.900 ratio and now for the $100 question.... what ratios were used in Subaru Transaxles ? I have a 93 Legacy SW and to the best I can recall the new trans was from a Impreza unknown year and the garage that replace the trans has went out of business.I did find some numbers on the trans ..TZ1022A3BA-G9 829464, can it be ID from this number ? or does it mean anything at all. I see that many talk about changing the rear diff to match and that's where I'm headed if I can ID the ratio I need. Thanks A Million .... Congrats to Nipper on the 5000 posts.... You are a true wealth of Subaru knowledge !
This is a long shot but one never knows until you ask. I purchased a 96 OB Wagon 2.5 DOHC, it was a one owner from the search done with carfax and I feel from the looks of things that it has allways been serviced at a Subaru dealer, all filters and such are Subaru. The wagon has 110,000 miles and I was wondering about the timing belt replacement,without tearing it down to check, which if I did that I might as well replace. The question ....... is there a way to check with Subaru for a maintance record by VIN # ? This could save me from wondering....
