Everything posted by Virrdog
When you first go to start the car... do you see the CHECK ENGINE light come on and then go off once the engine has started? How old is your exhaust? Possibly a broken up cat? And if you pull fine with half throttle, but it won't go at full throttle I would suspect the engine running too rich. O2 sensor?
Feels like axles are binding in 4WD
Virrdog replied to Anthenium's topic in Old Gen.: 80's GL/DL/XT/Loyales...
4x4 is for slippery conditions only to prevent this binding. There is no center differential to allow the front and rear wheels to travel at different speeds. -
finaly got the Ej20G wagon on the dyno
Virrdog replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very nice. Mustang dyno's are heartbreakers for sure, people get so caught in getting pretty numbers. -
Left and right tensioners along with the idler sprocket are also nice to replace while you are in there. Don't have part numbers, but the stuff can be seen what it looks like in this auction. Item #160033590073
I never thought I'd be posting one of these major goof-up threads, but here goes... I walked into my darkening garage and grabbed what I thought was the tranny fluid bottle. It is the same shape but a different color than the oil bottles. Needless to say as I start pouring it in I notice the color is not right and that I have indeed grabbed 10w-30 oil. I stopped immediately and filled the rest with the correct tranny fluid. Maybe 2-3 oz of oil was poured in. Am I ok? Any need to flush the rack now, or will it be alright... TIA.
Rear-facing jump seats in back of wagon?
Virrdog replied to ShakotanBoogie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just watch out for the gas tank if you want to bolt it to the floor. -
MAF sensor cleaning...who'd a thunk!
Virrdog replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry, wasn't trying to state generalities of driving in general. I used bad wording. MAF cleaning: Definitely helped cold engine hesitation. Air Filter & Plugs: Definitely helped highway speeds. But MAF very well may have helped horsepower up top, too. I was trying to differentiate between the various items I changed since I broke the rule of one variable at a time. Bottom line, MAF cleaning is definitely a winner. I might have to see how the element looks on the Sport Sedan now. -
EA82 water pump replacement with AC
Virrdog replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Entirely possible. Twas my first time messing with the front of any EA engine. I was also on a cleaning kick with the car. So I probably would have separated them anyways. I spent more time cleaning parts than I did actually removing/installing them. -
I cleaned my MAF along with a new air filter and spark plugs. I replaced the ignition wires when I did the timing belt a month ago. (New car to me, have no idea how old parts are). The old plugs looked ok and were gapped an extra one thousandth from use. Old air filter did not look all that bad. Overall car has more power now. I had trouble getting to 80 mph a couple of weeks ago, prompting me to find the hp loser. Now the car does that and plenty when given the gas. Had the stuttering and hesitating on cold starts and now that seems to mostly be gone. The car gives one good hesitation right as you start out, tries to die, then drives just fine. Low throttle cruising before the car is warm is much smoother. Extra power is in part due to a new air filter and spark plugs. Better low throttle cruising when cold must have been from MAF cleaning (and maybe some of the extra power). Next: PCV Valve and check the cap & rotor. Oh yeah, and brakes. -
Painting the hatch, need some suggestions....
Virrdog replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Black and gold sounds sexy. But tinting the windows and going with white wheels and black stripes would make a nice Panda theme. -
I'm back..this time Loyale morning issue
Virrdog replied to Rick James's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm chasing down the cold engine hesitating gremlins... Any chance I can get that .pdf ? I have my Multi Meter ready and waiting. I changed out the air filter, cleaned the MAF sensor, changed the spark plugs and my wife said that at one point it was hesitating a lot worse. -
1. I did, could not see a way around it. 2. Unbolt the alternator and then the compressor. Pull the compressor up and daisy chain some zip ties so it will be held away from the bracket. Then take out the bracket. Can be a little tricky and sometimes a second pair of hands holding the compressor in place would be a lifesaver. -
Internal/Recycled Air Button on EA-82/L-Series
Virrdog replied to hilux_1990's topic in Old Gen.: 80's GL/DL/XT/Loyales...
One of the first things I did with my wagon and it will actually get cold enough to turn the fan down on a hot day. You have to get the premium metallic tint, though. That will actually reflect a lot of the light off the window instead of absorbing it.
