Everything posted by newsoobdude
Daang! Got any more pics? Who did the lift and how much of one is it?
Documented: The 1970 FF-1 Project car...
newsoobdude replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Looks good to me but what does the stocker or other option look like (too lazy to re-read the entire thread)? As for your T-bars, what about completely shaved with just the stock openings? Or a simple 2 or 3 inch pipe chromed or silver in the rear for some rear end protection (think old school gassers). Coming along nicely, wish I was in the area to check her out but wont be back up that way for a while. -
You'd be looking for a first gen Legacy transmission as your 1998 Outback final drive is 4.11:1 and the earlier gens are 3.9:1. Not sure if the regular Legacy of the same gen (1995-1999) are 3.9 but someone with more knowledge will surely chime in. Check cars101.com for more info. Good luck and check the overall lengths as you might have to change out your drive shaft and DO NOT FORGET THE REAR END ALSO.
Yeah no kidding!!! They were going to change a guy $50 a side to replace his hood struts in labor alone!?!?!?!?! They ended up trying to charge me $150 for the strut assembly then more for "missing" parts even though all they had to do was assemble the strut yet couldn't even get the parts. Took them the weekend to tell me that, then they lost some of my parts too:banghead::banghead: Will NEVER have them touch my car nor purchase from them as they were extremely rude too. I ended up spending right around a grand to replace all 4 struts installed by me yet assembled by someone else as I've never dealt with struts before.
DO want pics when done. Trying to figure out a "clean" version for mine. Less- how close is the gap between your strut and tire? A spacer might make all the difference for fitment. I'd take it by a tire shop when done and have them test fit what you want (and BTW, I think you said you wanted BFG A/Ts in the 215/70/16s but they are, or at least were a month ago, on back order til further notice, hence why I'm running Grabber AT2s).
When I replaced the struts in my 98 with new 04 Forester KYBs and used springs I ended up having a shop do it as it was a big PITA to do off the car. They charged me $150 but PepBoys said they'd do it for $20 a strut but they tried to shaft me so I just picked them back up and took them to the shop. Real easy to reinstall once together through. Good luck and post pics when done.
Cool! Looks just like mine. As soon as the rain clears up and I get the gumption I guess I'll crawl back under and remove the factory spacers and track down another set of bolts. How close are the A/Ts to your struts? I have about a fingers space between the tire and the strut bottom.
Which struts did you end up going with, Outback or Forester? I don't head down to Venice very often but would be cool to meet up at some point and compare rides. Another member lives in Turlock if I remember as well as a few others around the greater helL A area. Good luck on the project and be sure to post pics. Are you going to be doing the strut install yourself or taking it to a shop? As for wheeling in the Valley, there is only one spot I know of but I used to go up to Angeles Crest and go to the hang glider take off spot but forgot the combo to the gate as it's been a number of years since I'd been up there and the old fire roads to the camp grounds and other spots have been blocked due to the fires so need to find some new places. Go to Gorman every so often but it's only dirt roads no real wheeling unless you don't mind body damage or have better ground clearance.
Daang!!! That looks sweet! What manufacture are those tires and how much do they rub? I have 215/70/16s on my 3 inch body lifted Outback on Forester struts and springs and they rubbed the trailing edge of the front fenders and inner wells when turning sharp. Can you get a shot of the rear trailing arms and axle shafts for me please? I'm wondering if they sit flat or not as mine are and I'm thinking of removing the rear Outback blocks for another inch of diff clearance.
Yeah, I've seen the thread and was going to try and re-find it when the time came and see if it ever got finished. Never did think about the going to the 3.9 and the better rpms at highway speeds. I'm going to be trying that same hill again now that I've got new taller tires and see what happens. It plus the fact I like to crawl around some parts is the reason I want the D/r to begin with. I do like the fact that my ride gets up to speed quickly with the 4.11s and that's what I'm afraid of loosing as I hate being the slug getting on helL As freeways.
Hate to say it but, it depends on what tire you get. I've seen 215/75/15 BFG A/Ts on Forester strut lift. If I remember right he rubbed on his front fender edges and inner fenders. I had 205/70/15s on my Outback before lifting and know 215/70/16s are a tight fit and required front fender trailing edge trimming as well as fender well massaging with my 3 inch Highguys lift and Forester struts. As long as you don't hit the strut its self you're good to go. Best thing to do would be go to a big tire shop and test fit different tire manufactures/ sizes. Just out of curiosity though, why the saggy butt spacers with stock suspension? I thought they were only required if running Forester struts and springs or WRX springs and struts for the lowering crowd . Post some pics when you get her done as we ALL love pics, especially of lifted sedans (well, at least I do )
How does it do with the 3.9 in slow speeds with the tires in high range? That and how is the acceleration? I didn't loose much if any and would prefer to keep it that way. Also, how bad do you rub and did you have to trim your fenders with the new nice arse tires?
Depends on what you're doin. Before I lifted my Outback I went up a nice steep hill slow because of ruts and what not and thankfully the tires slipped a little bit to get the revs back up because it was going to die. Tried to go up some other steep hills and stalled due to lack of speed and gearing but I didn't want to fly up the hill either. In my opinion it could really use at least a "low" gear (think granny) for the manuals but a true low range would be :clap:. And thats with the factory 4.11s and 205/70/15s. Now that I'm running 215/70/16s, I REALLY could use a low range, but would like to keep the full time and 4.11s so that means either S.O.L. or hunting Down Unda for one because Subaru Au still has (or at least had) the low range option available on new Subies. (4.11s going to be hard to find and the low range gearing isn't up to par depending on the trans. so needs a new gear set too)
I'd be a little leery of putting Forester struts on a regular Legacy. I have them on my Outback and my front control arms are pushed down a bit. (Granted I forget if they were before lift and struts so....) I'd recommend just going with Outback struts as you'll end up being an inch taller than an Outback if memory serves me right (I know it's taller but don't recall spec.). Where abouts in LA are you?
Your exhaust sounds fine to me. Loud but not too loud and deep as well. Still has the "boxer rumble" just at a deeper resonance. Are you gonna put your exhaust back up in the stock location and run it under the rear cross member or end it before the axle? Was looking at mine and I'm thinking I might just run mine out the side, but I want to keep it as high as possible too, hence not under the axle even though it's factory.
Had one that mounted in the window jamb that was from Autozone or something back in the day but don't have access to the car nor pics so sorry. Ones that hang from the door are ok but not sturdy for anything more than a 20oz and thats pushin it. Like the one that everyones posted pics of on the center console and the Impreza one is sweet.
I designed the bumper and had my friend do the fab work. The lift I bought from Gloyale and Highguys. It's only a 3 inch lift, but I did the Forester strut swap as well for a little more height. Thanks for the complement.
yes the car is my DD. The suspension (lift + struts) and rims/ tires ran me $2500. Bumper was done for another 6. Rides good so far but I haven't pushed it yet, finished it yesterday.
