86BRATMAN
    24
Everything posted by 86BRATMAN
  1. On-board diagnostic systems. obd2 is standardized, and is more sensitive to whats going on with the motor and emissions system.
  2. They are in pretty much the same place on the ej motors, and because of the placement the heat kills them off. Making them brittle and they eventually crack to bits...
  3. It had the standardize scanner port. So I would assume with that, and subaru converted them all in 96. For the obd1's there are a couple connectors that you plug in under the dash and it flashes the cel at you for the code sequence.
  4. I've personally seen one in a 97 brighton, it was obd2 and the egr was in the same spot as an ej22. I believe that 97 was the last year for the motor stateside.
  5. I'm pretty sure the pump mechanism could be flipped over and then it woul make it oump back into the passages correctly.
  6. They are swappable, but you're gonna drop your compression ratio throught the floor... http://wac.addr.com/auto/obs/turbo/ejcalcs.html You'd also be best off buying the head gaskets from cometic, they've got them made for putting 2.5 heads on a 2.2 block
  7. http://en.wikipedia.org/wiki/Isuzu_Aska According to this its a rebadged legacy. So I'd say they would interchange.
  8. I should have clarified my statement. I meant with the ej knuckle it would workfine.
  9. Ej18 and EJ20 rods are interchangable, not the pistons though. And you could make a turbo'd ej18. I know of someone on here doing it right now.
  10. I think the only twin pot's that will allow 15's are from the 91-94 turbo legacy, and possibly the outback and early gt's. The rear can be done, either by buying a kit from these guys http://www.crossbredperformance.com Or by extensive modification. But its costly either way for the rear.
  11. If you read carefully on the Crossbred site. You have to send them another set of backing plates as core. And the hubs are special machined parts to still use the ea axle. And yes, the e-brake parts on the legacy do mount to the backing plate. So no loss of ebarke needed.
  12. They will fit the xt-6 just fine. For the loyale you'll have to do the normal 5-lug conversion mods.
  13. You may be able to work with the man selling it. I've pm with him a few times, he seems to be a nice fellow.
  14. I'd recommend at least every once in a while "blowing" out the motor. You won't hurt the thing by getting up to red line. As 777 said its there for a reason.
  15. Does the brat have a/c? And does it only light up the lights when the pedal is fully depressed? If so, check for a short on the switch at the gas pedal.
  16. After reading this I thought I'd verify... http://www.cars101.com/subaru/impreza/impreza2003.html Just before half page it lists the WRX final drive as 3.90. It doesn't make mention of the reduction that we all know is there at the rear. And to confuse you more... http://www.cars101.com/subaru/impreza/wrxsti2007.html This page for the 07's says the wrx final drive is 3.0:1 and the STi is front 3.90, center 1.1:1, rear 3.545.
  17. Good to know that Will. This sounds like it should be a good running little beast.
  18. I'd do a little checking about the 03 wrx tranny. Everything I've read ahs said they had a 3.90 front final. And after the 06 year they switched to a 3.70.
  19. Are you sure it is actually the gear and not the cable for speedo itself. I've had the do some funky stuff when the speedo is going bad.
  20. Looks like the whipper snappers have the farts out numbered, lol. Thanks for doin that Mick.
