24
Everything posted by 86BRATMAN
Awesome stuff man.... BTW thats a huge banana
I would assume it would, I've changed ball joints by the jack method and it compresses the spring. When I changed out the struts on them. I'd leave the ball joint in, remove the strut from the knuckle, and disconnect the sway bar on that side to let it drop the lca more, bolt the strut to the tower and work it into the hole on the knuckle.
That could be one of two things. The other one could be bad, or that one could be stuck
it was random, I just wanted to subscribe so I could find out why...
Might it have something to do with some sort of thing that involved 5 of something?
How far from hitting the hole are you?
Unless they go to one of the two tracks where there are right turns.
look what i just got
86BRATMAN replied to desertsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Congrats man. I had called about that one. Guy didn't seem to know a whole lot about it. Said he hadn't driven it much because the clutch was slipping. You may be able to adjust it up and get some more miles out of that one. -
You are probably going to have to use more than just your strength to get it to compress enough to go in. Like a floor jack and a piece of wood on the hub.
What... Theres a ring there?? Nah, I think it goes flat side to pan.
Have you actually weighed the difference in the flywheels? Honestly... How much less would the flywheel weigh at xt6 spec. The clamping force would far outweigh the "loss" of a couple ounces.
This picture he sent me best dipicts where the piston is at. From the best of my memory it needs to go at least another 1/8 to 1/4 of an inch father in. I use the little tool that skip posted up, with a big 1/2 drive ratchet reduced down and a 3" extention. Gives me a lot of leverage on it.
This is 100% OT but. s'ko did you ever correct the camber issue on the brat. I mocked up the front 5-lug on a parts car today and toticed that even with the camber adjusted as far correct as I could I still had horrid looking camber. I'm thinking ea82 or xt6 lca's will fix the issue. Anyways, back OT... Glad to see its getting you around now. And you might want to look at a thread in the new gen area about making a hybrid ej18/ej20 headed turbo motor.
