24
Everything posted by 86BRATMAN
You did the smart thing getting it off the road while you could still drive it. Odds are it would have jumped time and left you stranded. I'd say it is time for a new tensioner, just to be on the safe side of things. It is a mojor pain to have to redo a timing belt job because you used an old one and it did exactlly this...
http://www.ultimatesubaru.org/forum/showthread.php?t=49975
Maybe you should look into a ej swap. Then ask him what he thinks
I know how you feel Connie. I cried when I relized how far gone my Brat has gotten. You are very very far away from that. A little bit of time, the lil' guy will be good as new. If you need any misc. parts I found another yard with about 8-10 ea82 bodystyle cars there that I can scrounge through for you as well.
I'm pretty sure the sender for the oil light only makes signal when the pressure is too low. It not being hooked up will never give a signal for the light to come on.
Always Check Those Air Filters
86BRATMAN replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rut ro raggy. That'll do it every time. My buddy lost a turbo on his wrx due to that same thing. Poor fellow only got a vf34 and STi topmount out of it:mad: -
easy way to do a clutch plate swap
86BRATMAN replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Either way you'll probably have to remove some exhaust parts. When I pulled the motor out of a turbo legacy I just unbolted the durbo from the down pipe, and undid all the bolts and mounts. Its really not that much more than a n/a motor. I've spoken with an older mechanic who said he has done them in ea81 cars by unbolting the motor from the trans and rocking it forward, and taking out the bolts(rotating motor to get to others) and put them back in that way too. -
In ea81 cars you'll have to remove the glove box door, then the inner section. Its held to the speaker mount with a screw. Unplug it and be done, no real need to remove it.
I've seen pics(in the Carlisle thread) of an ea82t wagon with the 84 turbo 4-spokes on it. Maybe the alloys were made with more clearance
Right, the knock sensor is designed to send a signal to the ecu if any spark knock(detonation) or any other for of knocking occurs. It then pulls 15 degrees of timing from the ignition system to try to correct the problem. Some have reported oversensitive knock sensors on motors with mild piston slap. And have relocated them due to this.
Rattling Maybe Knocking Sound?
It does almost sound like the inspection plate grabbing on the flywheel. Did you put it back on when you did the 4spd swap? Its not an engine related sound as I've known them. Rod knocks kinda sound like a midget with a ball peen hammer pecking, main knocks sound like a midget with a rubber mallot thumping. -
I've experianced the same problem too, in my white brat. It would spin around, bounce around like it had a mind of its own. IIRC I used a cluster from an 84 wagon in mine. So it would stand to reason that it will work from a hatch as well.
Modifying the EA81 pedal box to accept EJ Clutch Cable
86BRATMAN replied to 86BRATMAN's topic in Subaru Retrofitting
I do actually have another and a cable from an 86 brat. -
Come to think about it. There is a gl-10 wagon in the junk yard I'm going ot make every attempt at getting to this week. I'll see if its still got usable stuff out back
Loyale/Leone accessories page
86BRATMAN replied to DL92SW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Whats the link to the page. I'll see what I can do.
