24
Everything posted by 86BRATMAN
For those in rust free lands:
86BRATMAN replied to WoodsWagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, I'm the proud owner of a sadly decripid Brat that I bought after the point of no return. It really sucks, My hatch is getting surface rust in a few spots underneath. But it lived its live in CO before it came out here a few years back. Warm weather to me just means its time to get her on jackstands and go to work. BTW I won't sicken anybody further with pictures of my brat. -
I don't think the turbo cars have egr. But I could be wrong. Try giving the Idle Air Control a good cleaning. It bolts to the intake manifold near the throttle body, could have some crusty conections. Its just a shot in the dark. I haven't messed much with my 91 t-leg so I'm a newb with that particular motor.
Here's a weird wiring issue
86BRATMAN replied to 86BRATMAN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The wires and spade conectors in the plug looked to be in good condition. But they were sitting really close to the starter wire, which the rubber boot is missing from, so that may have been enough to make it ground out when the car was put into reverse. Also, when I was looking at my fusible links, I found that the middle one had been replaced with a piece of 14ga wire. I didn't think that was a good think, so I replaced it with one of the spares I have. -
AMEN!!!! I hated the bugeys's for a while, but I can't say that I don't like them now... Hell, in late 1989, when I was 6, I saw my first legacy and was like what is this. Give it a year or so for the new look to settle, and to experiance this new suspension design the Impreza line has gotten. People will be all over it then.
New Thread, 4wd doesn't work 86 GL
86BRATMAN replied to TheMeatWagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get a friend to move the 4wd selector, and you look under the hood, on the transmission. There is a lever that should be seen with the spare tire out. It is the 4Lo lever, if it moves with your buddy shifting the selector, check under the car at the point where the selector level goes into the tranny itself, this is the 4Hi lever. If both move like they should your problem is internal. -
Well, to add more frustration to the stupidity... I plugged the wiring back up for the reverse switch and 4wd indicator that I unplugged earlier. And now its not blowing the damned fuse.... -
No, the rear bumper is still std model, there isn't any real difference so I left it alone. I'm feeling like its more coincidence than conversion related myself. It didn't do it imediatly, just started out of nowhere yesterday afternoon. Untill I get my hands on a multi-meter and start chasing wire gremlins I've just unplugged the conector on the trans for the 4wd and reverse lights. Drove it around for an hour or so today, using reverse quite a few times with no problems. -
Well I thought that at first as well. But all I did was clip the plugs from the old side marker and turn signal and crimp them to the ones that go to the bumper mounted signal and new side marker. I haven't wired up the new high beams yet. I'm waiting on a trip to the junk yard to get a GL hatch wiring harness to pair up with my Brat dash. -
Ok, I just did the 4 square headlight conversion and gl bumper to my 87 std hatch. Now whenever I put the car into reverse it blow the ignition coil fuse. Any Ideas?
I've had this happen to me before. In my case the speedo cable was just worn out and had broken in two. If this is the case with yours, all I can say is that it is possible to change without taking out the guage cluster, but you'll need limber hands. Good Luck
How to identify Brat LSD
86BRATMAN replied to DPDISXR4Ti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From what I've read, the general consenus for the 91 model year is yes. 92-94 not even an option. -
Ummm. My auto 91 T-leg has a vlsd. So this is also incorrect. -
How much stiffer than n/a springs are the ones on the turbo cars of this vintage?
Auto's will be 3.70 open diff. manuals will be 3.90 open diff. -
None of them came stock with an lsd diff. But can be converted to such. -
Or if you are meaning for the spring pin at the tranny side you'll need a straight punch. I can't remember the size off hand, but it IS NOT 1/4 inch, that will get stuck real quick.
Excelent. I was about to ask this same question. I may be picking up an 84 t-wagon in a week or so
