24
Everything posted by 86BRATMAN
I didn't even notice the manual lol, next time pull the valve covers. You can get a large wrench on the cam to hold it in place to remove the bolt more easily. I don't think I have any extras at the momente, but I would have to look to be sure. But they are really common, I've seen a set or two posted on legacycentral and rs25 in the last couple weeks.
It's the forester springs that give the extra lift over outback. The front struts are identical heights for 98-08 forester and 96-99 outback (probably 00-04 as well). The rear struts from the outback are taller from knuckle mount to spring perch by about an inch, this only applies to the 96-99 vs 98-03. I have posted pictures in a couple other threads showing the difference in these.
The 90/91, 89/90 in your neck of the woods, models have lower spring spring perches. If you have those year struts you will have less clearance, but they may still fit.
Anyone built a reverse frankenmotor?
86BRATMAN replied to ystrdyisgone's topic in Subaru Retrofitting
Could you share your solution to the cam gear trigger pattern? -
Do much research on a wrx ecu swap with a phase 1 motor, there is a lot more involved than Chux make it sound. You'd be better off stuffing an entire wrx swap in the car than trying to get all the little things needed to run the ecu correctly. To my knowledge there are only a handful of people who have done it. -
How is the top on the 91? My brother had a 92 vert a few years back that was an absolute whore to keep warm in the winter because the seals were garbage.
The water and oil pump takes literally an extra half an hour at the most. I could see leaving the water pump til next timing belt as I usually only do them on every other change. But there is absolutely no reason not to pull off the oil pump to check the screws and do new seals. If the screws are loose it's just a matter of time before the motor loses oil pressure and eats bearings.
- 49 replies
- turbo
- timing belt
(and 3 more)
Tagged with:
Since your ej22 has egr the only thing you need to worry about is swapping the single port exhaust manifold. Just use the flywheel from the ej25d, probably a new clutch. Everything is a bolt in affair.
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
There are all sorts of details on legacy central about building a dohc ej22. You're probably searching the wrong terms, dohc ej22 or ej22d would yield some results. They aren't complicated really, if you can do head gaskets you can do this engine. Things you need from the ej25d, heads(duh), intake manifold, oil pan, oil pickup tube, dipstick tube and dipstick, black metal coolant pipe from water pump to heater core. You also need to run either a pair of oem ej22t or cometic ej22t head gaskets. You cannot use ej22e head gaskets or you have a quick blown head gasket because the coolant ports in the head are different. I've built a couple of these now, I can talk you through it. -
No differences in them at all. Just be sure you replace all the idlers and tensioner pulleys with the belt, the bearings are the most common fail point in the timing system.
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
Just basing this off your pictures and person experience, that's a 97/98 motor, from the coilpack and valvetrain and presence of egr. I've never heard of different timing belts for the ej22e, it's possible their listings are mixing in the ej222 which does in fact have a different timing belt. In the 15 years I've been working with ej series cars I've never seen a phase 1 sohc not use the same belt.
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
