				Posts4006
				Days Won24
Everything posted by 86BRATMAN
	  Is my Mechanic telling the truth? (82 GL)86BRATMAN replied to Ezekiel's topic in Old Gen.: 80's GL/DL/XT/Loyales... So which engine is in your wagon? If it's an ea81 I don't see how a '75 distributor would work in it. My old gen go to mechanic told me once that an ea71 distributor from the same year engine wouldn't work for my ea81 brat because the shaft length was different. Was there any sign of distributor failure before it died, such as the tach jumping around or skips in power. I feel like this guy is trying to take you for a ride personally.
	270k is a good haul for your transmission honestly. The transmission I used originally in my manual swap on my legacy gave up a bearing at about 280k. Most of what you've replaced is probably from normal wear, especially the clutch as the newer generation subarus make more power and weigh substantially more than the older generations did. So they will wear more quickly than one may be use to if coming from the old school, that also means the old school would wear that much faster if used with newer vehicles. I've ran across some dual range ej transmissions on eBay, when using a broad search such as "Subaru manual transmission" just you'll probably have to click on a bunch of the auctions but they will be in there. A lot of the sellers don't know the difference in the transmissions so you'll want to look over the pictures and verify the actual item shown is being sold.
- 8 replies
	- 1
		- Baja
- gearbox swap
					(and 1 more)
					Tagged with:
	I think the better question here is why. Why use a 30 year old transmission, why go through all the custom work like the engine adapter, redrilled flywheels, weaker clutch, custom made driveshaft, hard to find/custom front axles, swapped rear axles, custom shift linkage. Why not go for a ej dual range transmission and eliminate all the custom made BS and have a transmission that you can find upgraded clutches for and use most if not all of your original parts with.
- 8 replies
		- Baja
- gearbox swap
					(and 1 more)
					Tagged with:
	I must have skimmed over the part about only rears, disregard my clearance statement.
	You'll need at least 16" wheels to clear the calipers, or some strategic work with a grinder on the calipers to clear 15s. You'll want to grab the park brake cables from him, they will swap out fine with your existing cables. Just be sure to route then correctly.
	I could see a Brat in similar condition fetching 4k, that said you don't have a Brat. So it doesn't have the near cult-like following to help it's sale price. I'm going to have to agree with the general consensus here, $2500 max to someone who knows what it is and is actively looking for one.
	I'm uncertain if the loyale clutch fork will work with the ej transmission, but I've been out of the ea Era for quite a while. If it doesn't end up fitting correctly I have an ej cable clutch for taking up space in a drawer in my garage.
	Well at least he seems to have a worthy cause these days.
	I would murder tribes of small children for a clean coupe.
- 261 replies
	- 1
		- Restoration
- Coupe
- (and 4 more)
	Supposedly the 03-08 forester has longer rear struts similar to the outback. But I have never had a pair to verify. But there is a full inch difference from bolt hole to spring perch between 98-02 forester and 96-99 outback. My forester will be the second vehicle I've ran this type setup under. For a while last year I ran my legacy with outback strut and forester springs. This is where I first made the discovery for myself.
	So I just got in my 96-99 outback struts that I'm replacing the worn out struts on my 98 forester with. Here is a side by side comparison of the two with springs installed. My camera angle is a little off, but the bolt holes are lined up and you can see where the extra time clearance comes in. Installed pic to follow.
	The 610 is the correct gasket for the 25d. A person could run a thinner gasket and still be ok with the piston protrusion of the 25d, and keep the compression ratio closer to stock.
- 9 replies
		- franken motor
- 2.2
					(and 1 more)
					Tagged with:
	Do not use the ej22e head gaskets, the coolant passages don't line up with the head. Also as Shawn said, power will be pretty low with that combo as it yields a much lower compression ratio. It is in the neighborhood of 8.7:1 which is good for a diy turbo, but bad for naturally aspirated.
- 9 replies
		- franken motor
- 2.2
					(and 1 more)
					Tagged with:
