24
Everything posted by 86BRATMAN
2003 Impreza with 2.2 engine?
86BRATMAN replied to rick1077's topic in Meet n' Greet. Your USMB Welcome Center
rs25.com, plenty of members in socal there. Maybe you can find some of the parts you need there.- 7 replies
- 2003 Impreza
- 2.2 liter engine
(and 1 more)
Tagged with:
My fab work involved a hammer and angle grinder lol, thinking back I may have had to grind a small section on the bumper support to clear the light brackets. I have that bumper off the car now so I can take a look at it later this evening.
Was three threads really necessary?
You'll need new rear top hats and front perches to use them. These however are made to fit your car. http://www.andysautosport.com/subaru/1995_1999_legacy/suspension/lowering_springs/h_and_r/ they have the years listed wrong, they fit 92-99.
I fitted 00-04 fogs in my 96-99 outback bumper, it wasn't perfect but it functioned. Bent the 00-04 brackets and slotted one of the mount holes to fit my bumper support. You'd have to fab a small bracket to secure the lower stud to the bumper itself.
Old video, but I still get a kick out of it. And yeah, very quick brat.
oh, is this the video of the maroon one with the turbo sticking through the hood?
My phone won't play the video, but if it is a wrx swapped brat it's not the first and it won't be the last. The Australians have had wrx powered brats running 10 second quarter miles for 10 years lol.
Right, do not try any more to rotate it. I had an incident when timing one of these, when going to rotate the engine after timing it, that the tensioner hadn't fully extended and it allowed the crank to turn several degrees without the driver's side intake came turning at all.
- 17 replies
It shouldn't take that much force to rotate the motor at this point. If it were me I'd put the crank back to its timing mark, quadruple check every mark and go from there. The dohc motors can be a pain when it comes to timing belts.
- 17 replies
Idle Air Motor
86BRATMAN replied to Marg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Passenger's side of the manifold, bolted to the back, it has a 1" black hose running from the intake pipe to it. -
The STi gasket doesn't raise compression by a whole lot, going off memory it puts it up to 10.4:1 which with the way the ecu is tuned on the 251 is still ok on regular. I'm going to be repairing my mom's outback the same way this summer. You're results could be a combination of things, like a thinner hg and carbon build up on the pistons and chambers.
