24
Everything posted by 86BRATMAN
Polish Me Head
86BRATMAN replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No Mugs, phase 2 is only 99-01 for the ej22. But being a 00 model car you'll run into some other issues running phase 1manifold off phase 2 ecu. -
For the ea82 crossmember it strictly depends on which style ej mount you have. There are some with and some without the nubs, without nubs no need to drill.
Polish Me Head
Phase 2 ej22 heads have the same combustion chamber size as ej251, won't make a bit of difference to the compression ratio. But will make it so you don't have to change the exhaust manifold. -
Yes we used the 25d rods, it was a 97 shortblock and they went in no problem. No protrusion from the cyl like the 25d normally does. The 99 25d uses the same pistons as the 97/98, as long as you're sure the pistons are 251 then you are good. Use some STi head gaskets and 25d heads and enjoy high compression.
86BRATMAN replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sadly they all have to end somewhere -
Winterforces are a great snow and ice tire. We ran them 2 winters ago on the delivery truck at work, 2wd ranger, I had no trouble at all getting around with them. Another really good snow tire is a Mastercraft Glacier-Grip if you have anyone who sells them in your area. They're made by Cooper, so probably anyone who sells Cooper should have a line on them as well.
The system shouldn't be that hard to completely remove. Get your head up under the dash and find the 4x6x1 black box with the wires attached to it. Track each of them down to their respective taps and disconnect them. I recently swapped the keyless entry from one legacy to another, it can be a little time consuming but nothing that can be done with simple tools and some patience.
Should I buy an AWD Pontiac Vibe?
86BRATMAN replied to avk's topic in Non Soob Cars and Bikes Discussion
Nope... -
You will need to use your ej25 throttle body at the very least. Best bet would be to swap over everything between the two manifolds. The simplest way to do this conversion would be to find a 95-98 ej22 complete intake manifold, with egr because your ej25 has it and the 92 ej22 does not. There is a thread in the USRM section outlining how to work around that problem, check it out http://www.ultimatesubaru.org/forum/topic/137829-using-a-non-egr-engine-in-subaru-with-egr-exhaust-gas-recirculation-valve/?do=findComment&comment=1160910
ej22 prices
86BRATMAN replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Since you have a complete ej25d to begin with, like I did, you'll see what I'm talking about on that bracket. I may have it backwards been a few months since I built mine and a lot of stuff has gone on in between lol. Basically, anything when the long block is done it should look exactly like the 25d did. -
My first 86 had the brackets pop riveted to the body.
ej22 prices
Looks like a 94-96 to me lol. Oh and to the coolant pipe for the ej25d heads, you'll need the one from the water pump that feeds to the heater core. Thats the only one that needs to be changed. The bracket that hold the timing belt tensioner will either need to be modified, metal tab that the bolt goes through to the ej22 timing cover needs to go away. -
ej22 prices
Shoul be right at the same weight as the ej22 shortblock. I can lift both of them with about the same effort. -
You know that injector link is per injector pricing right?
