24
Everything posted by 86BRATMAN
4x140 to 5x100 bolt pattern adapters
86BRATMAN replied to matts87glsedan's topic in Products for your Subaru
I'm going to have to pull my order for the pair, had some stuff come up, and we'll, money needs to go elsewhere. -
EA82 & EA81 3AT the same?
86BRATMAN replied to BratRod's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a perfectly good reason lol, I parted out an auto brat and thought it might come in handy just in case. I have no idea its condition other than the brat had around 90k miles, a seized engine, and no rear frame to hold anything up lol. I packrat stuff when I have the opporatunity. As far as shipping it, I don't have a problem with that if you wanted to do the leg work. I can provide an address and fork lift loading for pickup. And can probably get ahold of a good pallet, banding straps, and shrink wrap. -
If you weren't so far away I'd give you the 3at in my basement to get it out of the way. -
love to, but I don't have any pictures of the process. it's been better 6 years since I've done it.
I got one of them on the preorder sale a few months back. Very nice shirt. I didn't realize they did another run of them or I would have got another.
On my push button 4wd XT I had to lay under the car about halfway back to get to the 4wd lever when mine was stuck. I had ran it as a rwd for a while when I was broke and had a bad axle.
- 38 replies
I didn't see any mention of whether or not the thermostat had anything on it, just trying to cover any potential problem bases. There should be no real damage done to the engine by running no thermostat for a short while, I wouldn't recommend prolonged running without it though. But I've seen it done to mask the overheating on a blown head gasket ej25 a few times in my life, usually when they are being sold or traded.
The power mode mod is on my list, I don't have any extra harnesses around to get the right size pin from currently(waiting on a trip to the salvage yards). Also waiting on the cometic gaskets to show up, were back ordered when I ordered them. I've got 6 left over pistons, ended up buying 10 to get a full set of "B"s for my block, if you decide to do another they probably aren't going anywhere lol. I've been over your build tread a few times on one of the other forums, quite impressed by your fuel mileage results.
It almost sounds like there has been some stop leak or something ran in the car, was there any kind of build up on the thermostat when you took it out? Did you refill the engine through the top radiator hose into the engine or just fill the radiator. You could still have some stray air pockets in there.
I don't remember specifically on the ea82, but the ej engines use gasket glue on the oil pumps. It is far superior to any cork gasket material.
Here in Virginia it's illegal to sell a used cat (at least for a salvage yard), it's also illegal for a shop to install used ones. I am not sure if it's federally or locally regulated. But that's the way it is here, if you can find someone who is parting one out and you can do the work yourself you should get subaru cats back on there. What symptoms were presented initially to warrant replacing the cats? I've never gutted subaru cats, but other makes running obd2 will throw a cel when it's done. I have no reason to believe ours would act any different, so you'd still have to run the spacer if you gutted them.
