24
Everything posted by 86BRATMAN
ngk plugs and subaru wires is the usual recomendation
- 14 replies
- Mile per gallon
- power
(and 2 more)
Tagged with:
Ea71 with HLAS and points?
86BRATMAN replied to mikaleda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a 2wd 86 standard hatch as a parts car a few years ago, otherwise was an ea71 car, but I didn't pay much attention to details on it -
My birthday present: 1984 Subaru GL
86BRATMAN replied to Walldo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wagon doors will not fit, only brat hatchback and coupe doors are long enough -
205/75/15 will clear no problem, and there are some decent options in that size as well
thats a big negative, I haven't seen a straight one in years
I've got some of the various trim pieces you're missing in good condition. Looks good so far, can't wait to see what you do with it down the road.
I had two of the high grade 15" audiobahn subs and a 3200w class d mono block I think it was a boss amp, I really don't remember it's been 10 years since I was into the big audio stuff, in the back of a Brighton legacy wagon, db'd 153 on the meter the club had at the time. My glass never suffered, couldn't keep that torx bit screw for the mirror tight though lol
You can dolly it no problem. Its only the ft4wd and awd ones you have to worry about.
It'll be the same work on any brat 82-87, there were no ea82 brats built. You'll need the driveshaft, tranny mounts made up, carrier bearing mount made. And you'll have to search and find what you need for the hybrid axles to have the 25 spline ends for the trans.
I know its been covered here a time or two, keywords are your enemy with searching effectively. But the wiring for the engine will be basically the same as whats covered in the ea-ej swap guides. Your 99 is a phase 2 ej22, which limits parts interchange to 99-01 ej22's and phase 2 ej25s. Look for an xt6 manual trans crossmember, will make mounting the transmission a breeze. You'll also have to switch over to 25 spline ea82 turbo axles if keeping stock hubs. There will be some custom work to the shifter I can't remember if it needs to be shortened or lengthened right off hand. The rear diff should be a non-issue, check the codes on the transmission, but it should be a 3.90:1 ratio which means keep your rear diff in place. Your driveshaft will need to be shortened ~2 inches if memory serves. I know I'm missing some stuff, wait for Numbchux to chime in, he'll pick up where I've missed or where I'm mistaken
I've done quite a few rattle can band aid jobs, if I could make a recomendation on the paint use the krylon rust tough line. The nozzle on the can fans the paint out in a similar spray pattern to an actual gun and it is so much easier to make a beter looking job with it.
most of the info on this swap is for turbo application, here is a good compression ratio chart, parts of it are inaccurate as it doesn't break down years of engines and their different stock ratios. http://www.b4et.com/docs/cr_matrix.pdf Realistic expected ratio with that combo is 9.0-9.3:1 which wouldn't be too bad for a non turbo application. You won't need to worry about the valves unless you go with a really thin head gasket or shave the heads too far. BTW, if i could find a good set of 97-99 ej25 heads I'd do something like this as well.
honda boys talking smack. need motor ideas
86BRATMAN replied to drake13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
B20 vtec dyno'd at 207whp, with 11.7:1, stage 2 cams, upgraded IM, and a chipped ecu. -
If the kid can drive and that engine is built right you're gonna need a wrx swap to beat it. I've had a built b20 vtec back in my racing days, my buddy's vf39, sti tmic, sti injector, 3" tbe, spt intake. cobb access port tuned 04 wrx couldn't hang. -
I'm no fabricator, but it seems to me to be safer and more effectice to build a complete body for the strut cartrige to slide down into, and weld your bottom and spring perch onto. Maybe with a threaded end sort of like the older toyota cars like my mk2 supra has on top to change out cartriges. That way its easily replaced and not comprimised in the build process.
