24
Everything posted by 86BRATMAN
ECU still thinks its an automatic (5MT swap)
86BRATMAN replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
do you still have the tcu plugged in, or does that even apply to the 3at -
just so there is no misunderstanding, the OP is on the east end of the country, 90s loyales are not a common item by a long shot over here.
Yes it does, the c/v angles will still be quite harsh on the components.
Been a while since i've been on here....
86BRATMAN replied to Ceejus's topic in Meet n' Greet. Your USMB Welcome Center
Sounds like the rear diff was probably rebuilt thinking that would cure the torque bind the tranny has, and when it didn't fix it the driveshaft was removed again. I've pulled the driveshaft to trade off a gen1 legacy with torque bind before without it being noticed. I wouldn't give more than 500 for it definately. Because even if I'm wrong in assuming torque bind to begin with, its most likely got it now due to the d/s being gone. -
The 84 turbo wagon I parted out years ago did not have power mirrors, but one that was in the junkyard about the same time did. Check your wiring is the best way to tell.
If you have a smartphone, use the photobucket app to post photo links.
I must have air trapped somewhere
86BRATMAN replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another thing to consider is the age of the rubber lines. Check them out for signs of fatigue. I had to do them on my mk2 supra back over the summer. -
My New very first Brat '86'!! I'm so SO HAPPY!!
86BRATMAN replied to Dinky26's topic in Members Rides
what are those wheels from, they look really nice on there, congrats man -
either way you've stated works, I'm not sure about 2wd struts dropping it that much. I got 2 out of 2wd with a coil cut off. plenty of info on here tho, just search it up, some of my old treads have some info there too
I have been using vvme.com for my HID's for about 3-4 years. I ran the 55w once, and the bulb burnt out in one of the within 5 months. The 35w kit I have in my supra has been there since early 09 with no problems.
The bellhousing you need is the one from the ea81 bodystyle ea71 motors. If tht made any sense.
at 26 years old, I'd blame the washer pump first, replace it first and go from there
Emergencey: Stolen Legacy Seattle!
86BRATMAN replied to Ratty2Austin's topic in Meet n' Greet. Your USMB Welcome Center
seems like subarus have been a target lately, there was a guy on legacy central that had his stolen, recovered, and stolen again before the tow truck arrived. Zap's son's impreza, and now yours. I hope she makes a safe return, I feel for you. -
Looks like a nice Brat you have there, I've actually got a seat with that pattern in storage. Can't remember right now if its drivers or passengers.
Following his other threads its an 88 gl hatchback, ea81 car.
miata shocks can fit ea81 cars as well
yes, they will work, but spring rate will make for an old ride as the front springs will be substantially higher than the rear torsion bars. A work around for this is to purchase miata front shocks, and ea82 top hats for the rear, declock the torsion bars and let the springs do the work.
