86BRATMAN
    24
Everything posted by 86BRATMAN
  1. For future reference, a better way to remove the lower ball joint without the pickle fork is to use a hammer and hit the edges of the lca after you take the joint nut off. Been doing this for a while and though they can be stubborn and require some pounding at times you'll save your ball joints from damage. And if you're worried about damaging the lca, use a brass hammer.
  2. that is what I had always read too, that's why the other post confused me.
  3. I've got an ej22t ecu out of a 91 floating around somewhere.
  4. auto yes, California emissions no, my mom's 98 L auto had it too, and it was federal as well.
  5. I've seen flamethrower kits make out of just that setup online before lol.
  6. Personally, after reading about the hypermiling. I think thats a little ridicoulous. I've been around quite a few ej's in my days. And even with my heavy footed late teenage years I never got less than 23mpg. The 98 legacy L, auto, with 200k+ miles that we sold about 3 years ago averaged 25 in town and 29-31 highway. I've never bought into the silly fads for increasing mpg.
  7. you can get a small drop by running 2wd front struts and springs. There are no off the shelf "subaru springs" for the ea81 cars. I haven't had the parts in my hands in near 5 years. But when I did it on my hatch I used 4wd springs with 1.5 coils cut off on 2wd struts. Best to use an angle grinder so it won't generate as much heat and ruin the spring. If I could find the old spring dimensions post there is a possibility of a few options for springs that will work.
  8. check my old threads man. Pm me if you want to talk about it
  9. tell him you know a guy that will make him a great deal on a roof cut and tops off an 86.
  10. I just want to say first off, I hate the east coast. And congrats on another good looking project.
  11. Am I missing something, my 97 ej22 intake manifold has egr
  12. thats the air conditioner condensor drain. Not his issue as he stated no ac on the car.
  13. Nice to see some solid results from a frankenmotor. Looks good.
  14. neither of those will work, I would probably limit the search to early ea81 cars, that advice will probably come in handy at the auto parts stores too. Advance use to always give us the wrong parts when looking up stuff for the 86 brat when we started asking for 84 stuff the computer got it right.
  15. http://www.ebay.com/itm/Chrome-Factory-OEM-Nissan-Infiniti-Style-Wheel-Lug-Nuts-Mag-Seat-Qty-25-/110961061437?fits=Make:Nissan|Model:Pathfinder&hash=item19d5cb6e3d&item=110961061437&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
  16. Hood will fit from and ea81 body car, 80-84 wagon, sedan, coupe,and 81-87 brat, or 80-88 hatch will be the same. The fenders from the same will work as well however the early years have the radio aerial on the drivers side, i think 80-82 but I'm not 100% on that. Coupe and hatch doors will also fit the brat, but must use brat window glass.
  17. I always wanted to drop an Xtra cab on a regular cab frame and bob the bed like that.
  18. Do we really need to give an old subare an excuse to rust, just come to the east coast, if you can find one half the work is already done
  19. You'll be best in the long run if you do the swap to meticulously pull ever stitch of wiring from the RX, label it and place it in a safe place. You'll need to put it in the wagon to run everything correctly. You'll need to fuel pump as well. Since the wagon is an auto you'll use the complete driveshaft, and trans crossmember from the coupe. Also IIRC all rx's had a rear lsd, use that and swap the rear disc brakes to the wagon. Also, keep in mind that the ea82t doesn't have the best track record with modifications.
  20. I just want to say that I love the look of the brat. And that your 84 speedo will have a vss attatched to it. If you search my posts in the retrofitting forum(or possibly old gen) there is a picture illustrating which plug it will be.
  21. I'm glad somebody got my point and didn't get bent out of shape by it. I didn't get to see one for a while after they were released, all I had to go on until then was just internet pictures. And they do not by any means do the cars justice. And yes, I agree they do need some help in certain areas with the looks. I for one enjoy the clean roofline look without racks and such, but I'm not everybody. Thats why there are dealer and aftermarket products.
  22. Yeah it will bolt over. The main difference is the turbo oil return is in that head itself, thats the tube in the bottom of the head closest to where the block should go.
  23. Lol, i'm fresh out of parts cars but have plenty of parts from them already pulled. If you were gonna do the swap the trans would have been yours and dropped off when I get back down to crossville to pick up a hatch:grin:
  24. Even a seamingly non noticable brake drag can effect fuel mileage. I have no reason to doubt that it *could* be causing this problem as well.
