About 98obster
- Birthday 12/07/1964
Location
Greeley
Vehicles
98 OBS & 97 Outback Ltd
98obster's Achievements
USMB is life! (4/11)
12
http://www.dirally.com/forums/showthread.php?20924-The-Unofficial-quot-How-to-Lift-your-Impreza-quot-Thread https://www.ingallseng.com/35420-14mm-fastcam-adjuster.html http://www.spcalignment.com/component/spc/?task=part_description&pid=81260®ion=USA&make=Subaru&model=Impreza&year=1993%20-%202007&from=USAFrom&to=USATo
do you have a pic of the tooth side? broken/cracked teeth=broken TB. Man, I want to drive to where you are and change that belt now not sure what your year is but: http://www.ebay.com/itm/03-97-98-2-2L-EJ22E-Subaru-Impreza-Legacy-SOHC16V-Timing-Belt-Kit-Water-Pump-/260923356471?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&vxp=mtr&hash=item3cc03e7537
i would include in your kit: PB blaster, vise grips, large flat head screwdriver. sometimes it is easier to cut through the brake line bracket and bend it back to free the brake line from the strut, I just ziptie after I install, ymmv. Also, use a 6 point 19mm socket, not 12 point, or use risk rounding the nut. also, rachet and open end 19mm wrench are helpful.
sounds like we need a timing belt party:drunk: . but seriously, if you can't confirm that the belt has been replaced, 165k is waaay overdue. may as well order a kit with tensioner and pulleys because when you get into it if the bearings sound like a skateboard-they also need to be changed. cracks in TB are almost never a good sign. just my .02 (adjusted for inflation).
I'm kinda in the same boat. IIRC, replacement belts should be 105k. You can remove the driver side timing cover to inspect the belt but I would probably question the remaining life in the tensioner and idler pulleys more than the belt itself, not to mention the WP and resealing the oil pump. congrats on having a 99 forester with 177k miles. 180k sounds like a nice round number to remember that the front end was done. Moon shot...It's a subaru thing:D
