About zstalker
- Birthday 10/25/1979
Gender
Male
Location
Los Alamos, NM
Vehicles
1999 Legacy, 1998 Forester
zstalker's Achievements
USMB is life! (4/11)
11
1984 GL-10 Hardtop Coupe FWD. EA81, Carter/Weber carburetor. Fuel pump isn't operating. If I provide fuel down the carburetor the engine will run properly until I stop fueling. Replaced fuel pump, and distributor (to provide proper ignition signal, the shaft had some play). I'm focusing on the Fuel Pump Control Unit (FPCU), but I'm not in a position where I can afford to experiments with a $150 new one without being fully convinced that it will remedy my situation. I need actual diagnostic information about this box specifically. Does anyone know the actual function of the FPCU? First off I'm a Subaru dealership technician, so I'm certainly not shooting blind, but I can't find any actual information about the operation of the FPCU. Using the factory service manual, Haynes, and Chiltons manuals I've been able to find almost nothing of what kind of output this module produces. The manuals all basically say " if power and ground are there, tach signal is coming in, then the pump will run." Yes, that's wonderful, but run how? From what I've figured the pump produces a pulsing power signal, since the pump does nothing and blows the breaker in the Powerprobe after a moment when I supply power and ground directly to the pump. A replacement pump (new) had the same result leading me to believe the pump needs a on-off pulsing power source to operate the plunger solenoid. Followup question: Has anyone ever found a way to bypass the FPCU? if it were as easy as a switch or a relay to provide bypassed power to the pump I would have done that, but that was not successful. Can any of the components inside the FPCU be replaced (resistors, capacitors, etc). I implore you USMB and your fountain of knowledge! ~Erik
http://www.gjparts.com/products/pistons&rings/NPR2008Book_catalog.pdf here's the NPR catalog for pistons and rings. NPR is who makes the rings that Subaru sells new. PN SWF20067 looks like yours...it's got the 1.5, 1.5, 3.0 rings sometimes Ebay comes up with results, sometimes Google will help
steering problem **need help**
zstalker replied to Lfreck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where in Utah are you? -
the vents are discontinued by Subaru, so no longer available new. At least in blue...that's what I've checked, I expect the same for grey and tan. good luck finding a good set, that's all...
EA81 Cylinder Head Question
zstalker replied to nitsuj80's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll be removing the engine from the car to pull the heads off anyways, the EA81 uses head studs instead of bolts, you do not have clearance to pull the head in the car. Even on later motors with head bolts, you don't even have room to pull all the bolts out with the engine in the car. You can leave the bolts hanging in the head, but still...tight clearance. ~Erik~ -
I would bet the dealer just saw that there wasn't a oil pump reseal "kit" and told the caller that to get rid of them. If makes me mad too, that's basically the attitude: we'll help only when it works for us. Any unnecessary parts lookup isnt' worth the time and effort. To reseal an EA81 oil pump it's only a couple O-rings and a gasket (external reseal), you just have to order them separately. Part numbers and MSRP list prices: 424207000 $1.80 806938020 $2.80 806914020 $0.90 These are the two O-rings and body gasket to reseal external leaks on an EA81 oil pump. note: some dealers have "adjusted" their list price, i.e. list+5% as ours does. you might be able to bargain, you may not. ~Erik~
Unknown disconnected wire under the hood
zstalker replied to smundr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd say it's not factory...if everything you need still works, I'd say take it out. ~Erik~ -
an automatic transmission is basically impossible to test or diagnose unless you can get the torque converter turning to get the fluid moving If you find out which wires the neutral switch uses you could bridge them to see if bypassing the switch will allow the engine to start. Pretty much like stated above, get the motor running first, and with a bad (or at least not connecting for some reason) neutral switch will 100% disable the engine. ~Erik~
try unplugging the sensor entirely and start the car. if the car runs better and just throws a trouble code (now ignoring the sensor feed), you've got a bad sensor or other sensor-related issue. I'm willing to bet you've still got an actual hard problem like timing. Are the Phase 1 and 2 crankshaft pulleys you switched clocked the same on the crankshaft? with the stumbling, it sounds like something somewhere is off... ~Erik~
it really does sound like timing still. I wonder if the change of the crankshaft sprocket has mixed something up. This possibly could be leading to a confusion between the crankshaft and camshaft position sensor signals as well, throwing the P0340. I'm not terribly experienced in building frankenstein motors, so someone else would have to chime in as to the compatibility of those sprockets and the timing marks. The stumbling really sounds like timing though... ~Erik~
I actually now have experience to say that basic 13" Subaru steel wheels will not fit backwards. The brake caliper and bracket on the Peugeot still stick out too far, and the rim won't seat against the hub. Looked like a crippled low-rider of some sort...very humourous. Then again, this was a Peugeot Turbo, so ohters may differ. ~Erik~
one thing we've found at our dealership is Mopar-branded Rust Penetrant. I don't know who manufacturers it, but it is RIGHTEOUS stuff...I want to name my next child after it. Like I said, I don't know who actually makes it, but I'd like to know so I can see if it's available in the aftermarket. ** anecdotal evidence: There was a 5th-wheel hitch ball threaded into a homemade brace installed under a truck bed I was trying to remove. No luck at all. I got a large pipe wrench (about 2' long), a cheater bar on it making it about 3 feet long. Added to that was a large pipe, about 4 feet long, so I was pulling more than 5 feet away from the ball. I got it to move about a thread's height out and doused the upper and lower threads with Mopar penetrant. Threaded it back in with the same tool combination. Let it sit and then was able to thread the whole hitch out with one finger on the end of the original pipe wrench alone...just spun it out! Other occations I've had a 100% success rate removing O2 sensors from Suzuki Verona catalysts where everyone else (not using penetrant) have about a 50% rate of having to rethread the bung after the sensor pulls the treads out. Amazing Stuff, but I'm really thinking I'm going to get some acetone and mix up some of my own and give it a shot. ~Erik~
awesome! congrats on passing. They're really pretty easy-going at that office there, as long as you're not going/calling to be a jerk about something. As for the fans coming on, I'd let the car idle till it gets to where the needle is heading into the hotter range and they haven't come one. Have you been able to turn them on by grounding the control wire manually? (i.e. with the key "on," backprobe the ECM connector at the wire that it uses to command on the fan relay) If they don't come on, you've got an electrical or fan problem. As crockettbrat said, my fan doesn't even come on till I'm sitting in traffic usually, so you might not even have a problem in the first place. ~Erik~
Back to getting the car to pass safety inspection and emissions, I'll be able to help you there. I'm an inspector over at Doug Smith Subaru. I won't pass things that shouln't pass, but I'll probably be more personable and helpful than most places...give you a more Subaru- and Old-Subaru-specific inspection (I'm rockin' an '84 Brat and '80 GL-10 Coupe). As far as getting the engine swap certified for emissions inspection, the guys down at the county emissions station in Springville are really great. They're a bunch of car guys and as long as you don't go in there being a jerk, they'll be really helpful. It's a really simple procedure...I got my SPFI Brat passed off, and Mark (the guy I deal with most) said that getting an EJ22 or EJ25 swap passed would be just as easy. Let me know anything I can do for you...including wiring, etc (if I have time...jeez, my life is crazy). ~Erik~
