Location
St. Cloud
Vehicles
1997 Outback
outbackusjunkus's Achievements
USMB is life! (4/11)
10
Sometimes they just stick together. I usually hit against the flat spot on the block above the starter first, have an old trowl w/o a handle, sharpened blade that I use there between the block and bell housing. Once you get it to crack a bit, putty knives or small screwdrivers work fine to work it apart evenly. Don't feel bad, the '05 I did on Sunday took an hour to work apart.
I'm trying to put a 2007 2.5 engine out of an smashed Outback into a good 2005 Outback, but the 2007 engine has some sensor looking deals on the front left head the '05 does not. I planned on using the '05 intake, but what are these sensors (or whatnot) and can I leave them unplugged? The '07 is the left pic, the '05 on the right, should be able to click to enlarge...
Wonder why the ECU swap didn't work. Did you still have the EGR solinoid wired up when you did? I did some more searching on this and I guess the computer switches the solenoid, then looks for changes in the O2 sensor reading to make sure the system is working. I think the non EGR ECU swap will be the only way to get rid of these codes, and w/all EGR wires cut so it doesn't start "looking" for something it thinks should be there. Thread Hijack...accomplished.
Problem solved...picked up a rolled '07 with only 34,000 miles for $1950 at a local salvage auction. Should be able to part out whats left and get my money back for the engine, plus won't have to dink around or even worry about gaskets, timing belts, etc.. Life is good. Also got the new '05 home...black on black...5 speed...movin' up. Anybody want to buy a rust free '97 OBW?
