About BigMattyD
- Birthday 12/21/1973
Contact Methods
Website URL
http://
Gender
Not Telling
Location
Syracuse, NY
Occupation
Eye Doc
Vehicles
03 Outback Wgn 4EAT
Recent Profile Visitors
BigMattyD's Achievements
Subaru Fanatic! (6/11)
10
Thanks for the reply. I probably don't HAVE to remove the engine, but I think it will be easier with it out. The clearance on the sides of the engine are pretty tight with my car. I've seen some people do it on youtube, but it involved a lot of moving the engine up and down, back and forth, and quite a bit of swearing. Also, I think it would be easier on my back to be able to work on the engine without having to bend over the side of the car. I have an engine hoist already, so I am leaning toward full engine removal. Then I could also check the rear seal or oil separator plate if necessary. I don't know. Maybe I am being stupid changing the HG, but I just think it would be easier to sell when fixed. There is some rust on the rear wheel wells like most other 03 outbacks I've seen, but mechanically it is pretty good otherwise. Matt.
I have a 2003 2.5 L AT Outback Wagon with 170000 miles. I have had a small external HG coolant and oil leak since about 120,000 miles, which has been worsening very slowly. It started on the drivers side gasket, but after a while, the passenger side gasket also developed a leak. It drips on the exhaust manifold, causing a burning smell, and occasionally some smoke. It runs well, but I will eventually want to sell or trade it in, and oil all over the bottom of the car is not a strong selling point! I am finally getting around to changing the head gaskets. When I remove the engine, I am planning to replace any other areas of potential leakage, such as cam and crank seals, valve cover and spark plug gaskets, etc. I changed the timing belt , water pump and thermostat at about 110,000 miles. I also replaced a bad timing belt idler at that time. I am planning to keep this car for probably a year or less, then try to sell it. Is there any need to change the rear main seal, or oil separator plate (as long as it's not the plastic one?) Plugs and wires are recent. I will be replacing the intake and exhaust gaskets, of course. Is there anything else I should be changing? Matt
While driving, the sound comes from the front but I can't tell which side. after I got home, I felt all 4 hubs, inside whe wheel. Basically, the center part of the brake rotor. The only one that was noticeably warmer was the front left. I have not jacked up the car to check the bearing noise for sure yet, but I think I may be on to it. It is hard though, to be sure that the extra heat on the left wasnt due to a draggy brake pad or something else.
Here are the details: 2003 Outback Wagon, AT. 166,000 miles Recently, there has been a pronounced humming noise and mild vibration, only when at speed above 40 mph and turning steering wheel to left side. Any magnitude of left steering causes this hum. When I go perfectly straight or to the right, there is no hum. The humming frequency changes with wheel speed but not engine speed. It is a mild, low frequency hum that sounds like rough pavement or tire hum, (kind of like a knobby tire or something). It is a noise that sounds like it is coming from the front of the car, but also a mild vibration felt in the floor of the vehicle and the steering wheel. Additional info: Right side inner drive axle boot is torn, and axle has been clicking mildly on steep right turns. All 4 tires just replaced. Noise is the same with the old or new tires. Wheel alignment was just done at time of tire replacement. No difference. A few weeks ago I had a NY state inspection. No issues noted RE: loose suspension components (ball joint, tie rod, etc.) I feel I should be looking for either worn suspension or steering parts or maybe a bad wheel bearing. Can anyone give me any further direction? Matt
Hello, I am getting ready to replace head gaskets on my 2.5L SOHC in my 2003 Outback. It has slowly been leaking coolant and oil externally for a couple of years now, and it is getting annoying. I have read that it is best to replace the original gaskets with the gaskets from the 2.5L Turbo version of the engine. Does anyone have the Subaru part number for this version of the head gaskets so I can make sure I get the right ones? Thanks, Matt
I had a problem with mice in my car last winter. They made nests under the carpet and in the center console, etc. I thoroughly vacummed and cleaned any area I could find evidence of mice. I actually had to lift up the carpet in the trunk, and the access panel for the spare tire, get underneath the plastic in the center console, etc. That really helped. I vacuumed out all their nesting and food storage, and made sure to keep the car spotless. It may also help to move the car and park somewhere else for a while. Matt
Wait, Now hold on a sec, are you a lady, Heartless? If I'd have known that, I'd never have helped you out!!!! Just Kidding, If you are indeed a female, I am glad to have helped. In fact, I have two young ladies of my own who sometimes help me with the cars, but far too infrequently, as they are both absorbed in princess stories and boys and the like. Props to all the ladies out there who are brave, smart, and cool enough to work on their cars! I only hope I can get my little ladies (5 and 6 yrs old now) to develop a love for wrenching on the vehicles! Matty D And Emilee and Bethany!
I just did the rear struts on my 2003 OBW, due to a need to make an emergency repair. The right rear strut's bottom spring seat rusted to the point that it let go of the strut tube, and the spring extended fully, (with an impressively loud BANG!) dropping the right rear corner all the way to the bumper-stop thingie. I ordered the KYB struts from RockAuto, and replaced both the rears. The struts themselves were still working fine, but I saw that the spring mount on the other side was pretty rusty too, so I figured its best to change them both at the same time. As far as I can tell, the KYB GR-2 (or Excel-G as they are now called) are the exact same strut as the OEM. I had a pair of Strut compressors called "MacStrut" that I had bought several years ago. Just to be safe, I bought a pair of the Harbor Freight Screw-type compressors right before the job, and I'm glad I did. On the first spring, one of the compressors twisted into a weird position, and I had to use a 3rd compressor to free it without causing a big problem. After that, I found that clamping a small pair of vise grips on the spring just "uphill" from the lower two-jaw clamp really helps to prevent it from "walking" up the ramp and getting skewed at an abnormal axis. The upper single jaw has the two J bolts with wing nuts to hold it in place, so that really doesnt seem to move as much. To take off the upper mounting nut, I used a deep 17mm socket that I held in a pair of vise grips, and the appropriate long handled allen key, again held with vise grips, to break the nut free, and remove it. Yes, you must compress the spring to do it properly. An uncompressed spring is just too long to allow the top to be mounted. As for mounting the spring compressor while the spring is still compressed on the vehicle: That's a personal choice. I briefly considered it before I removed the strut, but I just didn't see how it would be that much easier. It is very easy to attach and tighten the spring compressors after the strut is removed from the vehicle, and the tightening only takes a small amount of time with an impact wrench and a 24mm socket. I was careful to use the lowest possible torque setting on my wrench so I would not damage the compressors. I found that the HF compressors worked surprisingly well. No complaints at all, and for a great price. Matt
This may sound stupid, but maybe you could try sticking them down with some type of adhesive caulk applied to the back side? Like the kind you would use to seal doors and windows from lowe's or home depot? That might hold it down, yet be easy enough to scrape off if you ever wanted to remove it... Matt
