Birddog
Contact Methods
AIM
Birddoglogan
Website URL
http://
Location
Stuarts Draft,Va.
Interests
hunt,fish,golf
Occupation
machinist/welder
Birddog's Achievements
Member (2/11)
10
Just wanted to let yall know I finally figured out where that awful low sounding cylindrical noise that was coming from the center of my car was coming from.It was the outside wheel bearing on the passenger side.Finally changed that side out last week.The bearing was missing two balls and the metal cover that covers the bearings was sticking out about 1/4 inch.I have been lurking and searching for a long time,trying what others have found theirs to be and had no success.Just thought I would put this on here for someone else to see who may still be searching for their noise and have not tried this.Hope this helps somebody.
startup and idle problems with my loyale
Birddog replied to naz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can't access that link covering the post. If anyone knows what this problem may be, please re-post. Thanks -
i took a good purge control valve,cut the wires off near the connector,took a bad egr valve and cut the wires and cut it off near the valve.took the wires and conector from the egr valve and spliced it to the purge control valve and put it in the place for the egr valve.wasn't sure if it would work but they looked identical other than the connectors.it did make my egr code go away and i haven't noticed any thing different.
I built a basket to mount on my yakima rack,1a towers,but the towers don't fit really well.They seem like they are in bind.Could there be some shims or something I'm missing?Any body else had trouble hooking their yakima to a loyale?When I hokked it to my hatch it fit like a glove.THanks for any info
92' Loyalle front end noise....bearing?? Axel nut??
Birddog replied to travis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine is doing the same thing.i took it the subaru shop and asked one of the mechanics who has been there along time.he went for a ride with me and he said he didn't think it could be a wheel bearing because they usually make a higher pitched noise than what i have.he told me to check the oil level in my tanmission,which was bone dry so i filled it.the noise has not gone away.he said the transmission is not rebuildable.i guess i just drive it til it quits altogether, its got 234,00 miles on it. -
seafoam
Birddog replied to treeman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
could you explain the transmission flush.this is something i ought to do. -
91 loyale died on highway, no warning
Birddog replied to mountainbikeak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine stopped on the way home from work about a month ago.Thought it was the timing belts.Ended up the screw that holds the rotor button in place fell out.It would turn over but not start.Hope this helps. -
My brothers wife had a 84/85 hatch with a light behind the subaru emblem on the front grill.does anyone know how long they had these and what were they on?Do you ever come across these at the junkyard? Birddog
What was the water for?
Do you have an idea where the leak is coming from?
I'm gonna go look at a loyale tomarrow,it has 230,000 miles.How do these compare to the 85 hatch with an ea81 as far as durability and longevity?Are they simpler or harder to work on?What kind of mechanical failures are common. Thanks for your input, Birddog
okay,I couldn't get the original carb that I rebuilt to idle right.So I took a chance on one from the junkyard.(Hitachi).Didn't do anything but spray it out with carb cleaner and plug it in.Idles fine with just a little hesitation when step on the gas.Runs pretty good when I take it out on the road.But when I'm down on it and let off the gas it will spit and sputter through the exhaust and sometimes backfire.The original downfall pipe was wasted when I bought the car'so I replaced it with 2" stainless pipe back to about where the cat would connect to the 1 3/4 pipe .It is 1 3/4 back to the muffler,new turbo muffler.The question is should I take the car down and have interstate muffler run me 1 3/4 all the way back and see if my problems dissappear,or should I get a WEBER and see if they dissappear.I have been messing with this engine issue since christmas,and I'd like to be done with the body work before summer gets here.Thanks for your help. Birddog 85 gl 4wd
I guess I should have mentioned what I was puttin' it on.84 gl hatch 4wd.It doesn't have power steering.so I can put it on straight,right?Bear with me I'm still kinda new to this site.Have been reading for weeks but not posted much.thanks for the info
Gettin ready to swap to a weber,but I have a few questions.Is the connector for the electric choke the same or will it need need to be modified?What needs to be added if I get a carb with the water choke.The adapter plate,does any one have a picture or sketch of what it looks like.I could probably make it if I could see one.Does the coolant hole on the manifold get blocked off by the adapter plate or is there a hole for that too?And finally does any one have pictures or diagrams of the hose connections. Thanks
Has anyone experimented with a Rochester carb?A friend of mine has offered one he used on a 2.3 mustang that he races.
