gonehuntn
About gonehuntn
- Birthday 09/07/1959
Contact Methods
Website URL
http://
Location
Washington State
Interests
Subarus,hunting,shooting, fishing
Occupation
heavy equipment repair
gonehuntn's Achievements
Advanced Member (3/11)
10
My 84 GL Hatchback has 286,000 miles. It is going strong.
brian's subaru in burien? UPDATE!
gonehuntn replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep Still there. -
Question for guys with EA81 exhaust mods
gonehuntn replied to gonehuntn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bttt -
Thank you Shawn. Marshal gave me a call and is taking care of me. I owe you one. Tom
I have been trying to get hold of someone from MW Enterprises to get a axle shaft. I have not had any luck. I have left phone and email messages over the last couple of weeks. I have not gotten a response. Does anyone know if they are still in buisness?
I am very tired of changing front axel shafts
the sucker king..... I did put a heat shield over the CAT when I put the last axle shaft in. I was thinking that is why it lasted over a year this time. We had bought this car brand new in 85. The originol factory axles lasted about 200,000 niles. -
Thanx for the link chef_tim. I believe I will try them. -
84 hatch ignition problems
Yep, the module is the little black thingy inside the distributor. Some times called the igniter or distributor pick up. There are all kinds of reasons for a vehicle to run bad. Start with tune up including Air filter, fuel filter, and PVC, cap, rotor, and wires, plugs. Do a compression test. Check for vacuum leaks. Try some fuel conditioner and a different gas station. Then consider the modulator. While you are in there, pay attention to the play in the distributor shaft. -
update! I installed a new modulator. I have run it two weeks now with no fuses blown or ignition misses. BTW I traced the obviuose [easy ] circuits on the ignition side of the switch. Did not find anything suspiciouse. Now I have a water in the fuel problem to deal with. -
I believe I know where to pick up a ignitor pretty reasonable. I will give it a try. Thank you -
Repair Manual For An 87' Brat
gonehuntn replied to bitterbuffalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice looking Brat! Tell us about it. -
So you are thinking I have two problems? The miss, possibly corrected by swapping the coil & wires? Then you guys think the short is caused by one of the other circuits off the ignition side of the switch. I bought a new Haynes manual today. I will be looking at the circuits. -
The problem started with an intermittent miss. I could see the miss in the tack. The first suspect was the high output coil and 8mm wires. Of course I first took a good look at the cap, rotor and plugs. They looked good. I swapped the coil and wires back to original. The sooby seemed fine. I ran it for a day with no problems. The next morning I hoped into it fired it up and off to work I go. I have about a 48 mile each way commute in a remote area. It was 4:30AM. About half way to work the sooby just died. No sputtering, missing or anything, just dead. I grab a flashlight pop the hood, can’t find anything. I pull out the ignition fuse and it is blown. I pop in another fuse and it blew before the sooby even turned over. So I start walking to the nearest phone. It was about a mile and a half away and did not work. I walked to the next phone about a mile away and call my lovely bride. By now it is 5:30, she was very happy to hear from me....NOT! She is on her way anyway. So now I walk the two and a half miles back to the sooby, put in a new fuse, pop the hood wiggle wires n such. The @#$% thing fires right up just as the wife pulls up. I drive it home [no miss or anything], blow off work and go bear hunting. Next chance I get to work on it I change the cap, rotor, & plugs. I took a good look at all the wiring. It started right up and drove around the block. I worked around the house for a few hours then got in and tried to start it. The fuse blew again. I went through 4 fuses & no start. I ate dinner went back out and it fired right off again. So what am I down to here ladies and gentlemen? Distributor pickup? Ignition switch? I am looking for ideas here....HELP! lol
