About tforce
- Birthday 08/08/1977
Contact Methods
Website URL
www.skiwhitepass.com, www.evergreenmtb.org
Location
White Pass
Interests
Skiing, Snowboarding, Mt biking, Snowmobiling, Filming, Kayaking, Computers, Books, Subies
Occupation
Ski Ares IT Manager
Biography
Work at a ski area, live in the mountains, play outside.
Vehicles
13 Crosstrek, 01 Outback VDC, 01 Dodge Cummins
Recent Profile Visitors
tforce's Achievements
Advanced Member (3/11)
10
Before I go the route of just replacing the rear ext there's one question that's been nagging at me. I've read a few posts about the tube that sends fluid to the rear ext housing coming loose. I'm not clear on that one. Does it come loose inside the tranny or the rear ext? I'm hesitant to take the chance of putting together a good ext housing and then find out that the problem is inside the main part of the tranny.
That would be handy. I'll see if I can put together a decent Ext housing and maybe try that first. The tranny does have some other signs that make me wonder though. Shifts have been a little rough when it's cold and it takes awhile before it will shift from 3rd to 4th as it warms up. I did have to reseal the tranny pan recently...maybe it's leaking again and the fluid is getting low.
I saw this in another thread so I decided to try it just out of curiosity. I jacked up the drivers side of the car, unplugged the TCU, started the car and put it in neutral. Both wheels started spinning forward. I hit the brakes and after that, just the front wheel spun. I could move the rear wheel by hand in either direction while the front wheel was spinning and I could stop the front wheel by hand. There wasn't enough power behind it to move the car. Putting it in gear only got movement out of the front wheel. I plugged the TCU back in and tried it again. Same deal except the rear wheel didn't spin this time. I got a tiny bit of movement out of the rear wheel for just a second when I put it in Reverse. I have no idea what that means aside from fluid flowing where/when it shouldn't and I still need to swap the tranny. Just thought I'd share.
No TB in limp mode. Time for a tranny swap or maybe just time to get rid of the car and move on....or maybe I'll just park it till spring and work on it then. Anyone want an LSI for a project? It's got a few dings and rust spots already and it needs suspension work so it's a prime candidate for becoming an offroad toy.
I do have the old speed sensor so I'll have to track down an analog meter. The AWD did work at one point. I replaced the old tranny with a used one that had TB. I swapped the old rear ext on after grinding down the grooves on the clutch. Everything worked fine till the speedo bounce showed up. Replaced the speedo and that seemed to cure it...pretty much. AWD always seemed to be a little off after that but it did work for the most part. I'm curious to see what results I get from test #1. I doubt it's the sensor because I replaced it with the one from the old tranny and nothing changed but I'll test it anyway. Thanks John.
Well, the AWD has stopped working again. The first hard snow hit the other day and........suck. No indications as to what the problem is. No CEL, AT Oil Temp Light, Torque Bind, Speedo Bounce....nothing. Just no AWD. Tranny is shifting fine. Just replaced the pan gasket and the fluid looked fine. I little bit of sparkle in the bottom and some gunk on the magnet but no burning, metal fragments or anything else obviously wrong. Getting tired of working on this car. Was just about to put in a new steering rack, halfshaft and reseal the oil pan. Needs new struts and assorted suspension bushings too. Anyone have any deeper insights on what could be causing this issue? I have access to another tranny but I'm not sure I really wanna keep pouring time and money into this thing.
I would love to know where you get them for $20. Most of the local yards wanted $70+ to bring them in from another yard cuz they didn't have anything out back. I finally found a lot that had one left (out of 5 or 6 cars) for $35. Front end wreak so it wasn't in the dash anymore and the bezel was hosed.....don't know how long the thing was exposed to the weather.....and they still wanted the full $35. Luckily it still works. No more speedo bounce and the AWD seems to be working. Waiting for one last snow storm to really test it out. Thanks again for the help.
Didn't want to start a new thread so I'm hoping someone will pick up on this. I have swapped out both speed sensors and still have speedo bounce below 20mph.....doesn't tend to happen when the car is cold and first driven. Pan bolts were loose so some fluid had leaked out. Tightened em up, topped off fluid and things seem a little better than before. AWD seems to be decent above 30mph or so but barely there at driveway speeds. Rear left and front right wheels spun when I had the car lifted. Wandering where to go next. TCU, ECU, gauge cluster, pressure test the line to the tail housing? Just say screw it and put in a cheap tranny that I know is good?
Subaru recommended using a Vacu Bleeder.....never seen or heard of that but assuming it's a powered vacuum device of some sort. I just bled the system like you would a brake system. Only got a few small bubbles. Seems to fine working fine at the moment....weird. Can still push the slave cyl in by hand and pump the system back up to normal working pressure. Any recommendations on brand or place to buy a calibration box?
I know it's been awhile but I finally got the car fixed. I found a 03 Forester tranny at a shop in Bend, OR for $650. He got the tranny with torque bind and put a rear ext from another used tranny on it. The Forester has different inputs for the front driveaxles so the guy swapped the Forester inputs for the ones off my tranny and kept my old tranny for the work. There was nothing obviously broken in the old tranny but there was small flecks of metal scattered throughout the transmission....mainly in the teeth on some of the pieces in the rear ext. As far as we can tell the front driveaxle seals were leaking and the transmission got too hot. There were scorch marks in several spots. The most noticeable was on the areas between chambers where the carrier bearings sit. Car is driving great but there are two issues looming. 1. The speedo gear in the tranny is different then one on the Legacy my speedometer is reading 5mph higher than my actual speed. Anyone ever swapped one of these or know if can be swapped? I wouldn't care except I'm planning to sell the car. 2. Either my Master or Slave cylinder on the clutch system is failing but I don't know how to figure out which one it is. No leaks anywhere. No air in the system. The system randomly loses pressure slowly but can then be pumped up and then it's fine for awhile. I can push the plunger on the Slave cylinder by hand and recreate the pressure loss. Takes me about 30 secs to pump the system back to full pressure.
