Location
Virginia Beach, VA
Vehicles
I Love My Subaru
jbain8's Achievements
Advanced Member (3/11)
10
Hello everyone, I've been doing some offroading with my D/R buggy and now I feel I want to add a Nissan TCase for gearing and an automatic for crawling. My question is will the 3spd pushbutton single range auto's of the mid to late 80's handle 26in tires and a 1200 pound buggy? Thanks in advance
Great to see someone finally building one of these. I purchased the plans a couple years ago and so far I've only finished the EJ motor/DR Trans and drivetrain. Thought I would integrate the firewall and wiring harness from the donar car to help with the FI wiring, steering and brake issues. In the process of building a house right now so the Buggy is on hold. Great job so far and keep the pics coming.
Thanks guys that is kind of my problem, the same problem everyone has gearing, for some reason I hate the idea of adding a tcase even though it solves most of my problems. But it's big and heavy and I have alot of fab work to do to try and cram it high enough not to hurt my ground clearance. Then I have to lengthen my buggy to accomidate the monster. I was hoping just to get away with a fabricated lower control arms with 720 hubs and some custom axles up front giving my Lock in Lock out Hubs. I was thinking a set of 27 ATV tires would look pretty good. Jer
I'm building a Buggy which I assume will weigh in about 1500 pounds when complete. I want to run a 29 x 10.50 tire with with a Fuel Injected EA82 engine, 3.90 gears, and a D/R trans. This buggy is strictly for off-road use and will always be trailored. It's purpose is for moderate level trail stuff mostly family stuff with some moderate hill climbing. What I would like to know is if I ignored the high range, locked it in low range and made that my primary drive, what size tire could I run and keep the power roughly the same as if I had stock tire size in High Range. Thanks in advance for any help you can give me, I hope I didn't confuse anyone. Jer
ok then I think I'm a little confused, but lets try this I have an 95 2.2 wagon with a 5speed that has a bad engine. I have a fully refurbished 2.2 from a 94 wagon sittting on the engine stand needing a home. Can I swap the 94 2.2 block into a 95 wagon. This is only buggy stuff so codes and crap doesn't matter. I would just like to use what I already have to save money. Thanks in advace for any help you can give me.
Last of the EA Full Time boxes viscous ?
jbain8 replied to discopotato03's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the info I'm actually on my way to South America right now and was going to pick one up but now I'll just stick with my EA D/R instead. -
I don't mean to hijack this but I am also interested in the fabled EJ D/R....I'm in the Navy and will leave soon for a trip around South America hitting all the cool ports in Brazil, Chile, Peru....ect. Since I can look for it myself and shipping is free I'm seriously considering one to put behind my 2.2 in my buggy. What was the gear ratio in these trasmissions? Do they look just like a EA D/R but with a different bellhousing? And what can be done to modify them? Also if I blew a gear can I use parts from a EA D/R or am I stuck? I would love to not have to use a transfer case in my buggy (weight/length) and I want to run at least 29's any suggestions from our friends down under? Thanks in advance for any help you can give me. -
Crap Jon I just emailed you about buying that buggy....now my offer price will definately drop...... Jer
Hello all I'm looking for a little help on rims for my 95 legacy buggy. I plan on going with a 29 superswamper on an 8 inch rim with a 1 inch adapter. What I would like to know from the math guys is what is the max offset I can run and still keep from replacing bearings every month or so. Thanks in advance.
thanks alot, that helps alot now I know I'm going to use the D/R and the fact that the speedo is the same will also make things much easier.
