chadwick35/04
About chadwick35/04
- Birthday 11/06/1977
Location
Dalton
Interests
Cars, house projects
Occupation
Warehousing.
Biography
Subaru's are my life! On my 11th!
Vehicles
2009 Forester Premium
chadwick35/04's Achievements
Advanced Member (3/11)
10
Yikes, that's not good to hear at all, he was indeed thinking of trading it in, but it's also payed off to with no car payments, so if he has the repair done, you said it will return? He is also concerned that it will, i myself had no clue that 2005 and up had issues to i have a 09 forester myself and hope that doesn't creep up on me either, but i only have 20k on it to, i did work at a subaru dealership and remember 96-99 and then 00-04, both did them different, so at this point he is having the axle replaced then the headgasket next.
My uncle has a 2005 subaru outback in which he has bought from brand new, with current 83k on it, taken to the dealer to find only that the headgaskets are leaking? I thought by 2005 this issue was licked, now the fact is has 83k on it, that's not a good sign to me, very curious, then at the same time the axle boot was torn on the driver's side to, really? I suppose they are wear and tear, so please comment on this headgasket issue, thanks
Hello all I have a 2004 subaru legacy and the front driver and passenger side seat bolts and brackets are rusty and I cleaned them up as best as I could, I did call my local subaru dealer and they said it was commom from all the weather elements from getting in and out of the car, I did ask them if they have had any cases of them snapping or breaking and they said no, that makes me feel better there at least, so I would appreciate and comments or tips on this, cause it still bothers me and to me looks awful, I do want to replace the brackets and bolts, but that might be a cost issue there, so please let me know waht anyone thinks, thanks!
I have a 2004 subaru legacy and I am looking for a driver's side interior door panel a 2003 would work to, only legacy sedan and wagon, not outback, I am located in western massachusetts, berkshires,I did go to my local subaru dealer but they want around $260.00, that's a lot to me for a door panel, so please let me know, thanks.
Best Year For the Loyale, GL, DL
chadwick35/04 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well I had a 1989 gl turbo touring wagon with the raised roof and it was priceless, general maint, but other than that it ran like a a champ and was so dependable and so fun to drive it had 155k on it but the only thing that it rusted out and I had to get rid of it, which sucked I traded it in actaully then someone in vt took it and fixed it up I was so pissed, at that time I dind't have the extra money to fix the rust cause it turned to rot, it was a gl 4wd turbo model close to the gl10, I loved it so myself would say 89 ws a great year myself, good luck! -
Hello all I am looking for and having hard time finding without spending a lot of money, I have a 2004 subaru legacy sedan and I am looking for interior door panel, now if anyone has a 2003 that would work to cause they are the same interior, now this is for the legacy not the outback model, local junyards don't have them around here, does anyone have a clue where to try to find one, I tryed ebay and couldn't locate one , my locate subaru dealer priced one out for me $257.68 wow damn expensive so let me know all if anyone can help me out I would really appreciate it, thanks.
If you do ignore replacing the cat you will eventually lead to a no to hard start, reasoning is it's not doing it's job so by not replacing it, you will have these issues, 02 sensors to me are a temp fix but that code seems to come back. My 04 legacy just had a recall on that issue my ecm had to be reflashed due to that code issue and replacement cost.
Hey man , first let me clarify before you pull the motor for that rear seperator plate, I worked at a subaru dealer man and 2000 and up models had changed to a metal seperator plate so it's not that, I have a 2004 myself and I know that they are metal, now if you owned a model from 1999 and back then you had a plastic one, so it sounds to me like your oil pan needs to be removed and resealed, I just wanted to let you know about that before you pulled the motor and found the metal one instead to many people think that they were plastic beyond 2000 and they are not, trust me on this one I know from working at the subaru dealer for a long time, I had a 99 outback that had that seperator plate leak and the good part it was covered under warranty at that time so it costed me nothing.
