Everything posted by frag
1) IT's normal for the lines not to be aligned after even one rev of the belt. 2) Is this your first belt change? What marks did you use on the pulleys, Not the arrows I hope. 3) If you tried starting the car without the crankshaft pulley on, how is the crankshat sprocket being held in place? It's been a while since my last belt change, but I thing the pulley is what is holding the sprocket in place. If this sproket is not exactely where it should be, it wont trigger the crankshaft position sensor and the car will not start. Hope this helps.
P0141
frag replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Salt belt? No. I would call that brine soup if you want to know the truth! You're probably right about the corrosion. I will wait for warmer temp before I have a look at it. Have a good day. -
The only time I had steering slop, it was due to one of the univesal joints between the steering column and the steering rack being slack. I tightened one bolt and the problem was fixed. You might have a look there first since it's so easy to fix. Watch out, there are two inline universal joints there, and in my case the problem was with the second one (closest to the steering rack). It's a little out of view if you just look casualy. Good luck!
I'm no alternator expert but I strongly beleive that 15,6 volt is too much. Something's wrong with your alt cause it's sometimes reading low and sometime reading high. I think it's time you buy a digital multimeter (cheap) and do a series of tests. Just connect the meter's leads at the battery posts when the alt is charging. Look for something closer to 14 volts.
IIRC, the battery cable came with both connectors already attached. Maybe you could also pick up felt «doughnuts» that you put under both connectors to isolate them from the battery top. Finish the job by smearing dielectric grease, vaseline or about any other kind of grease on the terminals. Then, you should be ok for a long time.
