Everything posted by frag
No more music...
frag replied to jsaudy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Errands as in running some errands. "2 a : a short trip taken to attend to some business often for another <was on an errand for his mother> b : the object or purpose of such a trip " What would you guys do without us Canadians? :cool: -
Yes, i got that. But I thought that... 1) ...it was getting the thread on some politically icy surface and I felt you might not be up to it with your four seasons tires; 2) ...not being a true canadian ( ), it was'nt my duty to defend "our" collective economical honnor. :) :) :) :) :) :) :) :) :) etc.
Tests have been made up here (Montreal) which show that four seasons tires suck when the time comes to brake on snowy-icy surfaces. Four seasons might be an acceptable compromise for traction, but, where winter brings snow and ice and when the wheather is very cold (rubbert of 4 S. becomes too hard), they are dangerous when comes braking time and when your life and that of others is at stake. My dollar worth of comment.
No more music...
What kind of errants did you do ? Just in case it happens to me... -
2.5l Rule!!!!!!!!
frag replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Maybe he's afraid to give rise to any rumour of Him having anything to do with with a blow job... Sorry! -
I think you're only partially right. 10-30 oil has the base viscosity of 10 when cold and the base viscosity of 30 when hot. Nervertheless, hot grade 30 oil is thinner than cold grade 10 oil. Proof : when i start my car and it's cold outside, oil pressure is around 70-80 psi at idle and then goes progressively down until it's aroud 12 psi at idle when the engine reaches its operating temp. I use Mobil 1 10-30 but have seen the same thing happening with other oils.
In my case, I used a T fitting where the electrical pressure sender is (right below and behing the alt) and connected the mechanical sensor on one bar of the T and the regular electrical sender on the other side. Then you still have the idiot light working when pressure is at or near zero. I brought the pressure sender to my favorite part store and they found the right fittings for the job. I have no oil temp gauge though.
I've had some experience with ball joints pinch bolts first with a Loyale and then with my present Legacy. I broke the head of three of them and had to drill them thru and replace with bolt and nut. It holds very well, but drilling thru is not funny. On all of the others I used a acetylene torch (I have a portable set with small tanks). What seems to work best is heating almost to red the part in which the pinch bolt threads are. The female threads expand and the bolt can turn.
Yes, I've been on this board a few years and the consensus is that the torque value found in the shop manual and in Haynes is not high enough and that something around 120 ft-lb is more like it. That's the torque value I used three years ago when I replaced my belt and the pulley is still in perfect shape. Good luck!
I had the same problem once. Here's what solved it. Maybe it will work for you. Look where the steering column exit the firewall on the engine side. Follow the column to where there are TWO universal joints in line just before the column connects to the steering rack (you can access it from above). In my case the second one (lowest one) was loose. A turn of the ratchet solved the problem. Good luck!
I've installed a Fumoto years ago on my 96. Stories like this make me think I did the right thing. For those preoccupied with the possibility of something snagging the lever, it's not really a problem and by using different thickness of washers you can, if you're anal about it, install it so the control lever is tucked well away from anything that could snag it. My 2 cents.
