Everything posted by frag
1) The axle's nut is what's holding the hub and wheel in place. 2) Maybe you could separate the axle at the outboard CV joint and pull the rest of the axle from the trans. 3) If you do that you wont have any power in front (open diff) 4) All of the power will go to the rear. I guess one could do that and drive the car cautiously for a while. THAT'S ONLY AN OPINION. I REPLACED MY FRONT AXLES ONCE BUT NEVER HAD TO DEAL WITH SOMETHING LIKE YOU HAVE. EDIT: What is preventing you from driving with the shot right axle?
Wheel Bearings
frag replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have no difficulty believing that. When I replaced my front half-axles, I replaced the inner bearing seal as well and to this day keep asking myself how a dry seal like that can survive having even a new shaft outer cv cup rotating inside it for thousands of miles. I thought about packing the inside of the seal with grease but decided against it thinking that, if hot grease got past the seal and got onto the cup, it would attract sand and grind down the seal in no time. Anyone knows something specific about the solution of this "problem" ? -
For your sake, I sincerly hope there's a zero missing there somewhere! Edit: sorry, I misread your post. I guess one must read "has been up by about 50 miles" and not "up to about". Just my less than perfect command of the english language. By the way, what happens if, in the "edit" window, I click on "Go Advanced". I'm afraid to try...
If you go thru the trouble of replacing the PS fluid, then maybe do what some of us did here a while ago: replace the fluid with Mobil 1 AT synthetic fluid. Probably not necessary but might prolong the life of the system and is sure to give you a good feeling. Take care. P.-s.: To do the best job possible, remove the old fluid with a turkey baster (like said earlier). This will not remove all of the fluid. Put new fluid in. Start the engine and move the steering back and forth to mix the new with the old. Repeat that two or three times.
