Everything posted by frag
Coasting?
frag replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's way too timorous scrap487 ! Why did you stop halfway to the mark? Keep on cutting off parts until there's none left and buy a bicycle. What was your point? -
$1.84 Impreza
frag replied to pappy52's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
$1.84 ! Next time buy a dozen. I'll buy back one from you for $4.00. More than 100% profit ! Not bad. -
FWIW. The first time I replaced a timing belt was on my former Loyale. The timing was left retarded (and was later corrected at the distributor). The symptoms were very close to yours. The engine idled perfectly (even smoother than before) but the car had no power. Maybe your belt is one tooth off and the ECU "thinks" it's the knock sensor's fault. Good luck!
First thing I would do is replace the front O2 sensor if it has been there for 100k miles. The often stop working correctly without putting out a code. Others will give you more advice. The coolant temp sensor could also be a likely culprit. Get a Haynes manual to know how to test the different sensors. Good luck!
I think you're right. If you compare the 9003s and the 9004s, they show the same lumens output. The brightness icon though shows much more brightness for the EXtravision than for the standard halogen. ?????????? Go figure. I have the Extravision on my car right now. Have had them for 6 months and thought they threw more light on the road, specialy with the high beams. Maybe the placebo effect...
Timing Belt ??
frag replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Fine, thank you. Everything is developping according to the best scenario up to now. And a happy new year to you! -
Timing Belt ??
I dont remember having seen that part when I replaced the belt on my car (2.2L). But my memory is not what it used to be... -
A little smoke
frag replied to J_Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Look at your front CV joints boots. From what you describe - smoke coming from behind the engine and clicking noises - it very much looks like one of the CV joints boot is torn and is flinging grease on the cat and exhaust system. That's why it's not smoking just idling. It's probably axle replacement time. Good luck! -
Yes, the strut support is the part that bolts to the top of the strut tower. You can see three bolts and nuts protruding there on each side of the engine bay. These bolts could be loose, the top center nut (under the rubber cap) could be loose, or the bearing could be bad. If the problem is there of course. Merry Christmass!
If it's the joints in the steering shaft you should have steering play. It might take only a tunr of the ratchet to tighten the joint and cure the problem. If not it could be a broken spring or one of the strut supports gone bad. I had a noise like that one year ago when the top spiral of my front left spring broke due to corrosion. No other symptoms but the popping noise. Good luck!
It could be something else but that's the exact same symptoms I had both with the Loyale and the Legacy when the coolant temp sensor failed. The ECU thinks the engine is cold when it's hot and it sends too much gas and floods the engine. Make a search with "coolant temp sensor" here and you'll find lots of info on how to find and replace it. Meanwhile, you could floor the gas pedal when it refuses to start. On a injection intake this gives more air, not more gas and might help start the car even if the ECU is sending too much gas. Good luck!
