Everything posted by frag
oil question
frag replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think you'll get only opinions on this. Here's mine. I think they all have the same lubrication properties. The high mileage one is a heavier grade (10-30 at minimum) I think there are no «high mileage» 5-30 Mobil One oil. The longer change interval oil has additives that retard the apparition of contaminants of all sorts. I dont think switching between the three can have negative consequences. -
oil question
1996 Leg Brighton wagon. For the last three years or so i've been using Mobil One full synth extended (oil change) interval oil. One in the spring (10-30) and one in the fall (5-30). That's all. Of course, i replace the filter at the same time. I've got 364,000 kilometers on the meter and practicaly no loss of oil (leaks or burning) between changes. I had been using regular Mobil one synth before that. -
96 with OBD-1?
frag replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My 96 Brighton wagon was made in september 95 and it's OBD II. But like someone wrote, look at the lower left part of the dash just above the hood latch handle and see if there's a trap opening to an OBD II connector. OBD I have no connector at all. -
What is this?
How could a dealer make a mistake on this???! -
If you want to check the easiest first, have a look at the connection to the oil pressure sending unit (just below and behind the alt). I had the same flicker and it was the connector that was almost off. If it happens only at idle, it's maybe because the engine is vibrating more then. Just in case. Good luck!
96 Legacy Brighton. When I replaced the clutch a couple of years ago, the machine shop guy cut a few thousanths from the outher crown of the flywheel (where the pressure plate bolts on) to give the clutch "a little more grab". I dont know exactly how much he took off but the clutch has been working like a charm since. The flywheel was "stepped" just like yours. For what it's worth. Good luck !
I have almost exactly the same problem. Have to remove the rear carriage to repair the fuel tank and since there's rust all over (the rest of the car is not «pristine» but well able to sustain at least three more years of driving), I was tinking of replacing it with a used unit with less rust. Imdew reply gives me hope but grossgary's might be closer to the sad truth as far as my car in concerned.
seized motor?
frag replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks. Thinking about it, I guess it could also be used as an extra theft prevention system. -
seized motor?
Just ignorant and curious. What's the purpose of a negative ground disconnect switch? First time I hear about it. -
1) You crank the engine with the starter, the engine revs, piston go up and down but the belt does'nt move. 2) You push the car while in gear and the belt moves. Makes no sense to me. Turning the crank pulley bolt (if it's not stripped), cranking the starter or pushing the car in gear have one and the same effect : spinning the crankshaft. If the crank sprocket was broken off the crankshaft none of the aforementionned methods would move the belt.
