Everything posted by frag
This is something that has most probably not changed since 1996. It should be found near the driver's side strut tower. It is a shiny canister a tad smaller than an oil filter. There is a spring clip holding it in place. Undo this clip and the rest is intuitive. You might need a plair of battery pliers to get the fuel hoses to move before removing them. Most of the time the fuel system pressure goes away in a couple of hours ( I have a fuel pressure gauge) BUT I just went to my car and after two solid days parked at the same place the gauge is still registering 25+ psi. This is the absolute first time I've seen this happen. So it's most unlikely but possible. So have a rag ready and protect your eyes. Pressure or not there is only a small amount that will spill. Take care and stay away from the Purple Jesus while your're at it .
If it is like with my car, it's not a roller but some kind of a pad, spring loaded I think or at least pressure adjustable, that serves to hold the glass as it is raised or lowered. The problem is that pad (some kink of felt if I remember well) catches dirt or worst sand particules and that is what is streaking your glass. I tried cleaning, got rid of the streaks for a while but it came back. I now live with it. Good luck! EDit: In my case it's more than a streak, it is a series of long scratches.
The more recent ones are hard to pick. They usually cut the steering wheel. Mine is the "fork" type. One steel finger on each side of the steering wheel arms. So they have to cut at least at two different places and since those "fingers" are real close to the steering wheel arms, its not very easy. Like you said, reason enough maybe to skip your car and steal the nice red Honda next to it .
Quite simple story. The hatch latch mechanism works that way : there is a lever that the handle catches when you pull on it to open the hatch. Locking the hatch has the effect of pushing this lever aside and out of the handle's way (you then pull on the handle and nothing happens, nothing catches). Unlocking puts this lever back in front of the handle so it catches when you pull on the handle. When the handle mechanism becomes rusted the resistance becomes too much for the spring that brings back the handle towards the car. So when you unlock you put back the lever not in front of the handle but BEHIND it. You then pull on the handle and nothing happens till you do what I prescribed a couple of post before. A more permanent solution is of course to lubricate the mechanism with a anti-rust oil till the spring can once more automaticaly bring the handle back towards the hatch afer usage. Mine has been rusted since the moment i bought the car used but annual application of the proper lubricant has solved the problem for now.
Before removing the inside panel, try this just in case. 1) Lock the gate. 2) Push on the gate handle towards the front of the car. 3) Still holding the handle pushed forward, unlock the gate with your key. 4) Pull on the handle. If this works, report back and I'll tell you the rest of the story. If not, you've already got good advice on how to trouble shoot.
Static in the radio in tune with acceleration is a sign the alt is producing AC voltage that is not rectified. This often does'nt show if you just test the DC output voltage like the shop probably did. Take a multimeter, set it to AC voltage and connect the leads between ground and the alt output wire with the engine running. If there is more than 0.5 AC volt, the alternator diodes are bad.
There is only one sensor on your car. It sends its info to the ECU which in turn uses it to trim fuel, start the rad fans and control the temp gauge. That's why I think a non working temp gauge could be a sign there is a problem with that sensor or with its connexions which would cause also a fuel trim problem. It seems like a possibility to explore.
Just an opinion on "A". Its the exhaust gases that are entering the coolant system not the reverse cause exhaust pressure is much higher than coolant system pressure. So no coolant in the cylinders. These leaks are often very small and the coolant pressure at engine shut off is probably not high enough to force it's way past the gasket and to the cylinders. If you let things go and the leak becomes bigger, you might begin to see some white vapout at the tailpipe. From the top of my head...
Like I wrote in another thread where you mention your temp gauge being pegged at C, the coolant temp sensor which control via the ECU both the fuel trim and temp gauge is a likely culprit. If it has never been replaced, I would replace it since it's not very costly. If you ever had problem starting when the car's engine is hot, then the coolant sensor is almost certainly at fault.
